Potrail2378 Posted April 16, 2021 Share Posted April 16, 2021 Hi, I still have a £50 Christmas Amazon voucher from work, and was wondering about getting the Santa express train set, which is conveniently priced at fifty quid. I think it's R1248.Simple question - Can it be converted to DCC? Thanks in advance. Link to comment Share on other sites More sharing options...
Howbi Posted April 16, 2021 Share Posted April 16, 2021 Yes you can convert this loco to DCC but will need you to solder the decoder wires in place. The Hornby 4 pin decoder is ideal for this .........HB Link to comment Share on other sites More sharing options...
Potrail2378 Posted April 17, 2021 Author Share Posted April 17, 2021 Thanks, lt looks pretty straightforward. I'm just hoping the loco will be heavy enough, and reliable enough. Link to comment Share on other sites More sharing options...
96RAF Posted April 17, 2021 Share Posted April 17, 2021 The 0-4-0s are quite light. I couldn’t get one to trip my DC auto-shuttle, whereas a heavier tram and a diesel did trip it, although I spent a lot of time trouble shooting until I worked out the tiddler was the problem. Link to comment Share on other sites More sharing options...
Fishmanoz Posted April 18, 2021 Share Posted April 18, 2021 Converting modern 0-4-0s and 0-6-0s is dead simple. Pickups to decoder red and black, motor connections to decoder orange and grey (first disconnect everything from the motor and discard the capacitor). Check running before putting the body back and, if the loco runs backwards when your controller says forwards, swap orange and grey.It also matters not whether you use the 4-pin or 6-pin or 8-pin. They are all the same decoder except more functions can be accessed on the 6 and 8. You just have more function wires to cut off and stow with the larger decoders. Link to comment Share on other sites More sharing options...
