Christopher-1214885 Posted June 21, 2021 Share Posted June 21, 2021 I was given a Class 3F Jinty 0-6-0 No, 24 S&DJR as a gift and after investigating discovered that some were factory fitted with decoders. As I am about to embark on building a layout which will be DCC controlled I wanted to ascertain if the locomotive I have has DCC fitted. The Hornby box that it came in was labelled R2882 as part of the Railroad range and the locomotive is a very dark blue/black in colour with gold coloured SDJR lettering on the tanks and the numeral 24 gold in colour with a red outline. There is also a small logo on the right hand side of the cab entrance which appears to be 3P with 3G directly underneath. Can anybody throw any light on this identification and the DCC issue. Thanks Chris Link to comment Share on other sites More sharing options...
jane1707819582 Posted June 22, 2021 Share Posted June 22, 2021 Hello Christopher The 3p 3g means class 3 passenger class 3 goods .basically meaning the loco power pulling its stock.Now DCC fitted if you look at the rear of the loco you will see a little lug holding the body on .If you press this in and lift the shell it should pop off .look at the motor area and if DCC fitted you will see a decoder .usually a 4 pin . Link to comment Share on other sites More sharing options...
96RAF Posted June 22, 2021 Share Posted June 22, 2021 One way to check if a loco has a decoder fitted or not is to briefly place the loco on a DCC track. If it buzzes in protest then it definitely does not have a decoder.Do not leave such a loco on track as it is seeing full track potential as an AC voltage which will damage the motor. Link to comment Share on other sites More sharing options...
new lad on block Posted June 22, 2021 Share Posted June 22, 2021 Hi Christopher, the digital version of the SDJR loco with ‘24’ running number was originally produced in R1125 Somerset Belle train set. As originally produced the R2882 version was not digital.If I remember correctly, if the loco has a factory fitted chip, the loco normally has DCC on the baseplate.I will find out my example of the trainset to confirm later today. Regards Link to comment Share on other sites More sharing options...
new lad on block Posted June 22, 2021 Share Posted June 22, 2021 Hi, Christopher, as I thought the digital loco does have the inscription on the baseplate.It is still possible that the loco may have been fitted with a chip after it left the factory though. Photos to show loco. Link to comment Share on other sites More sharing options...
Christopher-1214885 Posted June 22, 2021 Author Share Posted June 22, 2021 Thanks for that feedback and the photos. This is exactly how the loco looks. Will check out the base plate and let you know. Link to comment Share on other sites More sharing options...
