Stephen-1211844 Posted July 13, 2021 Share Posted July 13, 2021 Hi, I have had a Centenary Peckett 614 R3825 for a couple of months and it has started making a continuous popping sound when its running (DCC). The popping isn't synchronised with the rotation of the wheels and I don't think its mechanical in that sense. It sounds like its being made by the motor. Could it be electrical? And is there anything I can do to remedy it? Its fitted with a Hornby R8249 decoder. Thanks. Link to comment Share on other sites More sharing options...
atom3624 Posted July 13, 2021 Share Posted July 13, 2021 Does it have sound?Sounds like this may be one for the DCC section.BEFORE that, I would check that the motor mount is fully 'nipped up'.You say it's not synchronised with the wheels, otherwise I'd say to check the pick-up wipers and also the rods aren't interfering, plus to 'nip up' (carefully) the coupling rod screws - CAREFUL, they're fragile.Al. Link to comment Share on other sites More sharing options...
Stephen-1211844 Posted July 13, 2021 Author Share Posted July 13, 2021 Thanks atom3624, but I've made sure everything everything is tightened up. Link to comment Share on other sites More sharing options...
Flashbang Posted July 19, 2021 Share Posted July 19, 2021 HiAs supplied, new this loco is not DCC Fitted. So you have fitted a Hornby R8249 decoder yourself. Is the decoder or its wiring touching anything when the body is fitted?If the above is proved not to be the cause then I would suggest, that if possible, you remove the decoder and refit the DC operation Blanking Plug then test the loco on pure DC on a separate piece of track that's not connected to the DCC system. If you do not have a DC (analogue) controller then use a new PP3 9volt battery connected across the rails. Note, the loco will not be controllable on a PP3 battery, but it should move forwards or in reverse happily!Does the "Popping" sound occur? If so, check for something that is not in the correct place - Wheel wiper bent. Con rod on one side (or both) bent etc. Link to comment Share on other sites More sharing options...
Stephen-1211844 Posted July 28, 2021 Author Share Posted July 28, 2021 Hi Flashbang, thanks. On DCC I took the body off and ran it: popping disappeared. I've checked the wires: seem fine. The wipers are all in contact. The metal around the chip is insulated with tape (not the chip itself). I've tried running it under DC (minus chip) on test track, with body, using a Guagemaster Combi: still pops. Very odd: I'm going to adjust the con rod nuts (need to buy a tool though). Link to comment Share on other sites More sharing options...
Flashbang Posted July 29, 2021 Share Posted July 29, 2021 HiIf the "Popping" is occurring under DC running then its probably something mechanical? Turn the loco upside-down and look carefully at left and right hand sides. Do any of the Con rods appear different? Do any wheel wipers not seem to be equal and not rub on the sides of the wheels internal face? All these can lead to a "Popping" sound, otherwise its something internal within the loco that needs investigating. Link to comment Share on other sites More sharing options...
RDS Posted August 16, 2021 Share Posted August 16, 2021 @StephenModerator Note:Could you please select the 'View my Community’ in your Dashboard on the Forum and choose a nickname in the ‘My profile' tab, rather than your First name that has been automatically allocated by the system. Hopefully a Forum change is coming soon to prevent this automatic allocation but a manual change is required at the moment and there is definitely more than one member with your name. Link to comment Share on other sites More sharing options...
