CM1707822547 Posted August 25, 2021 Share Posted August 25, 2021 Hope you can help. I have a Virgin Pendolino and the board is burnt out.The part No. on the board is 2451 X0061can anyone tell me where I might be able to buy this part?Many thanksCharlie Link to comment Share on other sites More sharing options...
RDS Posted August 25, 2021 Share Posted August 25, 2021 A Train Fair is likely to be your best bet and pickup a second hand one.What is the R Model Number because I think that this topic may be better in the General Discussion section of the Forum because even if it is DCC fitted, the main PCB should be common with a DC version. Link to comment Share on other sites More sharing options...
Going Spare Posted August 25, 2021 Share Posted August 25, 2021 Is the board in the powered or non-powered driving car, and was the unit supplied DCC-ready or DCC-fitted ?DCC-ready powered car part is X9728DCC-ready non-powered car - X9729DCC-fitted powered car - X9715DCC-fitted non-powered car - X9707All are in stock at Peters Spares and probably other part suppliers. Link to comment Share on other sites More sharing options...
CM1707822547 Posted August 25, 2021 Author Share Posted August 25, 2021 Thanks very much for taking the time to respond. I am in Toronto and there are no stores/shops here that trade in British stock.There is a Great British Train Show which is organized by the Platelayers group every two years but with Covid it has been two years since the last one.While there might be a couple of dealers none would have this part.the other thing is the cost of postage is outrageous , just look at what they charge on EBay to send the smallest item here.I need to look to see if the part is for the motorized or dummy carriage.thanks.Mod note: I have removed your re-quote of RDS's moderator note as obviously it wasn't relevant to your reply above. As a new Hornby forum member you may have been used to other forums having a reply button in the post. This Hornby forum doesn't work that way. To reply to any post, just scroll down and write your reply in the 'Reply Text Box' at the bottom of the page and click the Green 'Post Reply' button. The 'Blue button with white arrow' is not a 'Reply to this post' button. Link to comment Share on other sites More sharing options...
CM1707822547 Posted August 25, 2021 Author Share Posted August 25, 2021 A Train Fair is likely to be your best bet and pickup a second hand one.What is the R Model Number because I think that this topic may be better in the General Discussion section of the Forum because even if it is DCC fitted, the main PCB should be common with a DC version. Part of the problem is I am not clear on what the R number is. Link to comment Share on other sites More sharing options...
96RAF Posted August 26, 2021 Share Posted August 26, 2021 A Pendo with a factory fit decoder will have a 7-pin decoder - Fig 6. A DCC-Ready Pendo (ie has a socket for you to fit your own decoder) will have the 8-pin socket - Fig 7. Just by comparing your model with this grab from the maintenance sheet will confirm which of those part numbers listed by GS you will need. Link to comment Share on other sites More sharing options...
2old4this Posted January 22, 2022 Share Posted January 22, 2022 Hi Newbie to the forum...The two power boards look to have similar size, can the X9715 PB be replaced with the X9728 main PB. to make it 8 pin as the old 7 pin decoders are discontinued? Many thanks in advance Link to comment Share on other sites More sharing options...
96RAF Posted January 23, 2022 Share Posted January 23, 2022 Yes I would say so, just transfer the lighting, pickup and motor wires as applicable like for like from board to board. No soldering involved as the wires are held on by small plastic jumpers. Link to comment Share on other sites More sharing options...
2old4this Posted January 23, 2022 Share Posted January 23, 2022 Thanks for that , I will let you know how it goes Link to comment Share on other sites More sharing options...
2old4this Posted January 29, 2022 Share Posted January 29, 2022 Thanks for info Rob. This was very straightforward and I would recommend to anyone who has the 7 pin boards to convert to 8 pin Link to comment Share on other sites More sharing options...
96RAF Posted January 29, 2022 Share Posted January 29, 2022 Good to know it went well never2old Link to comment Share on other sites More sharing options...
