Kevin Hodges Posted September 15, 2021 Share Posted September 15, 2021 Hi guys,I want to add some tighter curves to my layout.Will Scalextric Sport C8206/SuperSlot S8206 R2 Curves work with my ARC PRO 24h Le Man's Digital Set ?Thanks in advance,Kev. Link to comment Share on other sites More sharing options...
Andy P. Posted September 15, 2021 Share Posted September 15, 2021 Google any of those items and look at the track connectors. If the connectors are the same they will work.No slot car manufacturer has made a track connector that looks the same but doesn't (!) work... thank goodness...By the way, the C8206 is the standard curve in ever single set out there sold since 2004 including your 24 Hour Le Mans set (which also has 90° R2 curves) You can get them for .01 of your favorite currency. When you say tighter did you mean less degree of curve?Tighter usually refers to radius. The various radii are explained here: http://www.janestrains.co.uk/ScalextricTrack.html Essentially there are 4.Does that help? Link to comment Share on other sites More sharing options...
Kevin Hodges Posted September 15, 2021 Author Share Posted September 15, 2021 Thanks Andy,Yes, that makes sense. I was getting confused with my R2 & R3.It must be the R1 I'm needing.Kev. Link to comment Share on other sites More sharing options...
Andy P. Posted September 16, 2021 Share Posted September 16, 2021 A lot of racers don't like R1 as you have to take them really slow, particularly on the inside.I think as long as you don't do something silly like having a 3 meter straight that ends in a 90° R1 you can use these tighter curves nicely.Personally I use 22.5° R2s or R3s followed by 22.5° R1s as hitting the first curve slows the car down a little and the curve is tighter than a pure R2 or R3 curve.It makes adding borders a pain but it makes for a nice layout in a lot of cases IMHO...BTW: There are lots of very high quality second-sources out there. Just make sure there is no crusty rust on it. Dark rails can be cleaned with a railroad track eraser... Link to comment Share on other sites More sharing options...
