Kevin Hodges Posted September 21, 2021 Share Posted September 21, 2021 Can anyone suggest a chip that will fit and work with a Scalextric Mini Cooper S ?Thanks Kev. Link to comment Share on other sites More sharing options...
Andy P. Posted September 21, 2021 Share Posted September 21, 2021 There is actually video on this: The other aftermarket, Scalxtric digital-compatible chips would be very similar. :-) Link to comment Share on other sites More sharing options...
Kevin Hodges Posted September 22, 2021 Author Share Posted September 22, 2021 Thanks Andy,I had watched this video before, but I still can't work out what chip he used.?It needs to have that same wiring harness configuration with the LED sensor on a separate wire.I've looked at many different chips on eBay including Slot.It models, But I cant find any with that style harness.CheersKev. Link to comment Share on other sites More sharing options...
Andy P. Posted September 22, 2021 Share Posted September 22, 2021 It's a bog standard C7005 Scalextric retro chip.Some of the newer ones look a little different but they function all the same.The harness is the same, essentially 2 sets of wires to go between the guide and the motor and a set with an LED on the end for the digital communication. Link to comment Share on other sites More sharing options...
Kevin Hodges Posted September 24, 2021 Author Share Posted September 24, 2021 Thanks Andy,I looked at this chip, but I couldn't see the separate LED lead.CheersKev. Link to comment Share on other sites More sharing options...
Andy P. Posted September 24, 2021 Share Posted September 24, 2021 Hi Kev,Not sure what you mean. There is always an LED on the end of a pair of wires.If it is still in its original packaging it will have the LED.I won't link to any suppliers as I figure you should use a supplier of your choice. :-) Link to comment Share on other sites More sharing options...
Kevin Hodges Posted September 24, 2021 Author Share Posted September 24, 2021 Hi Andy,I bought a Slot.It chip. The LED is built into the chip so you are very limited and it won't work in the Cooper S.I just wanted to make sure I bought one with the LED on a separate lead.The only chips I have experience with is the EasyFit.Kev. Link to comment Share on other sites More sharing options...
Andy P. Posted September 25, 2021 Share Posted September 25, 2021 Slot-IT has pretty good documentation online and I think there is a way to put an LED on cable but I am not sure.The standard retro chip though should work. Link to comment Share on other sites More sharing options...
Kevin Hodges Posted September 26, 2021 Author Share Posted September 26, 2021 Thank you Andy.CheersKev. Link to comment Share on other sites More sharing options...
