Trains1707822545 Posted October 18, 2021 Share Posted October 18, 2021 Does the Hornby elite support Sound latching for multi start decoders. Link to comment Share on other sites More sharing options...
96RAF Posted October 18, 2021 Share Posted October 18, 2021 Not sure what multi-start decoders are, but Elite function buttons are on-off if short pressed but if pressed and held they become momentary.Whether a function is one or the other is usually down to the decoder build not the controller e.g. TTS have play-once or repeat looping sounds. Pressing and holding a play-once sound will not keep it going, you have to select off then on again. Link to comment Share on other sites More sharing options...
Trains1707822545 Posted October 19, 2021 Author Share Posted October 19, 2021 They have options to run either a cold start or a Normal start on dcc Sound, some can even do a failed start. Link to comment Share on other sites More sharing options...
96RAF Posted October 19, 2021 Share Posted October 19, 2021 Yes - TTS has that on F9. F9 cold-start is selected before F1 sound-on is selected. Older TTS decoders had a fixed cold start sequence that played through then it would catch and settle to idle. Later TTS decoders have the enhanced cold start (ECS) where it plays a random set of fails to start until you deselect F9 whereupon it catches and settles to idle.I thought maybe you were talking dual mode locos like Class 73 electro-diesel or multiple engined locos like some DMUs or Deltic with two real motors in the one shell. Link to comment Share on other sites More sharing options...
