johnny1707821342 Posted November 19, 2021 Share Posted November 19, 2021 hiya guys when I put my power transformer into my select it doesn't power on and then when i give the end of the transformer a wiggle the select briefly says overload and switches off again don't know why this is happening please help cheersJohnny Link to comment Share on other sites More sharing options...
Chrissaf Posted November 19, 2021 Share Posted November 19, 2021 First of all, does this happen with the Select connected to the layout. If so, disconnect the 'Track' output of the Select and test again. Is anything then different? If so what. Link to comment Share on other sites More sharing options...
johnny1707821342 Posted December 8, 2021 Author Share Posted December 8, 2021 hiya sorry for getting back late to you tried it without track plugged in still does the same Link to comment Share on other sites More sharing options...
96RAF Posted December 9, 2021 Share Posted December 9, 2021 Do you have a multimeter that you can use to check the output from the transformer. It may be a dodgy socket in the Select so you have to prove the plug is OK first. If it seems to be the socket then get onto Hornby to see if they will repair it. Link to comment Share on other sites More sharing options...
johnny1707821342 Posted December 13, 2021 Author Share Posted December 13, 2021 yes i can do that do i put the red or black end into the output of the select Link to comment Share on other sites More sharing options...
96RAF Posted December 13, 2021 Share Posted December 13, 2021 You are trying to measure the output of the transformer to prove it is the correct value - put the red meter probe into the barrel of jack plug of the transformer that plugs into the Select and the black probe onto the outside of that barrel. You should get 15v DC when the transformer is switched on. That will prove the transformer is working. Do not apply the probes to the three pins that plug into the wall socket. You do not apply the meter probes to the Select.If the Select is still not booting up there is no other check you can make.If the Select boots up but fails if you wiggle the transformer jack plug, either the transformer lead is faulty, maybe a broken wire (try a different transformer) or the socket in the Select is faulty, which will require repair by Hornby unless you are adept with the soldering iron and can find the correct replacement socket. There has been a recent post about sourcing these. Link to comment Share on other sites More sharing options...
Chrissaf Posted December 13, 2021 Share Posted December 13, 2021 Sometimes to ensure a good connection between the red meter probe and the inner pin of the power supply DC connector [because the insulation on the meter probe is getting in the way] it can be more reliable to insert the end of a straightened paper clip into the connector and then touch the red meter probe to the paper clip. Link to comment Share on other sites More sharing options...
johnny1707821342 Posted December 17, 2021 Author Share Posted December 17, 2021 oh ok thanks will try that Link to comment Share on other sites More sharing options...
johnny1707821342 Posted December 21, 2021 Author Share Posted December 21, 2021 hiya guys just tested out with multi meter yesterday and indeed it looks to be my select which is at fault will contact hornby customer services and get in touch with having it repaired thanks again Link to comment Share on other sites More sharing options...
