Ducky1 Posted December 27, 2021 Share Posted December 27, 2021 I now have 23 locos loaded into RailMaster. When I open the Quick Select window I find that the bottom three have their description cut off. Is this just my computer or does anybody else find this and I should report it as a bug to RailMaster.Duck1 Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 27, 2021 Share Posted December 27, 2021 Given the very basic display requirements for RM, it’s unlikely to be your computer, so suggest you report it. Link to comment Share on other sites More sharing options...
St1ngr4y Posted December 28, 2021 Share Posted December 28, 2021 @Ducky1I have more locos than that, but the Quick Select window is one I never use. If you have more than 24 locos defined, you can see nothing at all of those past the first 24. What it needs is a vertical scroll bar down the right hand side. It would make it "not so Quick Select" to access those later locos !!Ray Link to comment Share on other sites More sharing options...
trickymundo Posted December 31, 2021 Share Posted December 31, 2021 Hi @Ducky1I use the Quick Select window just like you and I may have a few too many locomotives too. :-)Whilst Railmaster is rough round the edges this one is easily workroundable. As @St1nkg4y correctly says a scroll bar would help and wouldn't be too difficult to implement.However, the workaround is to 'drag' the centre part of the panel with the locos on it either with the mouse or on a Touch screen with your finger. This will give access to the lower locomotives on the screen quite easily.Cheers,Tricky Link to comment Share on other sites More sharing options...
96RAF Posted December 31, 2021 Share Posted December 31, 2021 The same click and drag is used on the large throttle functions screen to bring hidden buttons into view, so likely the loco frame was purposely designed that way. Link to comment Share on other sites More sharing options...
Ducky1 Posted December 31, 2021 Author Share Posted December 31, 2021 Thanks for the help. Scrolling the window works. I had already reported the problem to RailMaster and they said they would look into it for the next release. Link to comment Share on other sites More sharing options...
