wagonmaster Posted May 11, 2022 Share Posted May 11, 2022 during use locos running elite cuts out lights on unit go out then it appears to reset and restart then it runs awhile shuts down again latest version of software as its not very old 18 months since purchase Link to comment Share on other sites More sharing options...
96RAF Posted May 11, 2022 Share Posted May 11, 2022 How many locos running at once when this happens.Do you see anything on screen or does the display dim out then the Elite reboot.Do the locos start to run again on their own or do you have to reselect each and drive away. Link to comment Share on other sites More sharing options...
wagonmaster Posted May 12, 2022 Author Share Posted May 12, 2022 How many locos running at once when this happens.Do you see anything on screen or does the display dim out then the Elite reboot.Do the locos start to run again on their own or do you have to reselect each and drive away.only 2 locos running at any one time Link to comment Share on other sites More sharing options...
wagonmaster Posted May 12, 2022 Author Share Posted May 12, 2022 only 2 locos some time 3 thats all i have Link to comment Share on other sites More sharing options...
Flashbang Posted May 12, 2022 Share Posted May 12, 2022 Personally, I would remove all locos from the tracks and then ensure the Elite remains powered OK. If it does then turn off the Elite and add one loco. Power back up and run that one loco for a short while ensuring it runs correctly. If it does, power off the Elite and remove that loco and try another loco then do this same testing loco by loco until all have been tested. If any one loco causes the Elite to trip then investigate that loco as to the cause.If the Elite trips with no locos on the track as per the first check above, remove the two Track feed wires from the rear terminals and also the Programming wires if used. Power up Elite and see if it now trips. If it does suspect the power supply, its cable or the Elite itself. If its OK after a while, then the problem is in the track wiring or the track layout itself. Link to comment Share on other sites More sharing options...
96RAF Posted May 12, 2022 Share Posted May 12, 2022 only 2 locos some time 3 thats all i have That answers one question.The others ?An extra question - does it happen as you change points or a particular point. Link to comment Share on other sites More sharing options...
