Bachmann Class DCC Fitted Loco number only works 2 digits
Deem
Maybe someone could help.
I took out my Bachmann Class 20 DCC Fitted - try to rename and allocate 4 numbers address but Dynamis will change but Loco will not move, so I tried 3 numbers address but that didn't work either so I allocated 2 number address, loco worked straight away in DCC Mode.
My question or advice I need is
Is that something down to older decoder or the way Bachmann have designed decoder?
Please see attached pictures
forum_image_6289782c396bc.thumb.png.4c712188e30bab0b9d40acb19a610694.pngforum_image_62897830b83c0.thumb.png.a29a622bdb07cb8324922d08474cb6c7.pngforum_image_62897835a8ca5.thumb.png.01c5b8fe958afa85f50b2c4be3c9360b.png
Have you tried direct addressing CV 17&18
CV bit 5 on
I think you mean CV29 bit 5 on.
@Deem
Let us know the 4-digit address you want to use, and someone will tell you the values to put into CVs 17 & 18
Maybe the Dynamis doesn’t allow addresses > 99 ?
Ray
The decoder does not support CVs17/18 (long addressing) nor does it have bit 5 of CV 29 which switches short to long addressing. You are stuck with two digit addressing with this decoder.
Thanks 96RAF
Your explanation made things clear for me and I can understand the CV Leaflet better now.
Thanks Jupiter
I am going to sell this Loco which is in mint condition and either get Hornby Class 20 TTS or Bachmann Class 20 with sound.
Regards
