Express Point Track Spacing
I have loaded these pieces into the Track designer software 'AnyRail' and it looks as if it reduces the spacing by about 10mm. I will have another look tomorrow if I have any of the actual track pieces to see if I can get an accurate measurement, or another look at AnyRail to see if I can obtain a more accurate dimension.
I shall go out to the train room later and measure my track spacing - all points are Hornby Express.
Reading left to right across those rails - centre to centre ...
This end - left layby = 58mm, through rails = 68mm, right layby = 48mm
Far end - left = 58mm then centre = 75mm then right = 52mm
So obviously I flexed things a bit to make them fit.
According to Scarm I used R628s off the points.
