Dodge1965 Posted January 25, 2023 Share Posted January 25, 2023 I'm pretty sure i've seen something about this and tried a search in the Forum, but nothing.Which loco's can take stay alive in the TT range?Sorry if this has been covered. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 25, 2023 Share Posted January 25, 2023 All HM7000 decoders can be fitted with the power bank, so all locos. That said, there may be an issue with room on the 08 and other 0-6-0s when released. Will be interesting to see as these are the ones most likely to need it. Link to comment Share on other sites More sharing options...
Dodge1965 Posted January 25, 2023 Author Share Posted January 25, 2023 Fishy.. exactly that, sure i read some couldn't.. But can't find the info again. Thanks Link to comment Share on other sites More sharing options...
Paulchik Posted January 25, 2023 Share Posted January 25, 2023 Just a thought regarding smaller locos such as 0-6-0’sthinking back I’m sure I saw the possibility to run an extension from a decoder to a slave socket stored in an attached wagonyes it has disadvantages such as wires on show and the attached wagon has to been continuously connected to the locoBut is this an option for Stay a Live and or sound for smaller Locos ? Link to comment Share on other sites More sharing options...
96RAF Posted January 25, 2023 Share Posted January 25, 2023 Best of luck self wiring terminals onto wires to fit those tiny stay alive and speaker plugs and sockets. I gave up and went for pre-wired items. Link to comment Share on other sites More sharing options...
david_watts1 Posted January 25, 2023 Share Posted January 25, 2023 Using a wagon as a permanent 'tender' for a small locos speaker and stay alive is a possibility, the wires should be long enough. I'd replace the couplings with something permanent just to be on the safe side. The wires are very delicate.EDIT: I forgot they're using 6 pin in the 08 shunter and not a N18. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 25, 2023 Share Posted January 25, 2023 Agreed about wiring N18 plugs and sockets Rob but what about attaching a 6-pin plug to the 8TXS?There’s still the problem of getting it to fit given that extra piece of real estate on the sound PCB but it might be a possibility. Link to comment Share on other sites More sharing options...
96RAF Posted January 25, 2023 Share Posted January 25, 2023 Here are the respective decoder boards for comparison Fishy.Do you think you could hook up a 6-pin header to the 8-pin sound board to get a sound decoder for use in the small locos.This is the 8-pin version of the 6-pin (same PCB)Next 18S below.And the 8-pin TXS sound version - same board as Next 18S Link to comment Share on other sites More sharing options...
david_watts1 Posted January 25, 2023 Share Posted January 25, 2023 Does anyone do a 6pin male to 8pin female conversion plug/wire/socket? I see DCC Concepts do a 8pin male to 6 pin female lead. Then you could put the chip, speaker and stay alive all in the 'tender' wagon. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 25, 2023 Share Posted January 25, 2023 You’re right Rob, solder pads don’t appear to be big enough or in the right place, so not practical. Link to comment Share on other sites More sharing options...
TT-Man Posted January 26, 2023 Share Posted January 26, 2023 Always seems to be the way. The models that need a stay alive aren't capable of having one fitted. These days it's something that really should be sorted at the design stage. Given the marvels you see in N and Z, I don't see why it's not possible in TT. Link to comment Share on other sites More sharing options...
M. Matthews Posted January 26, 2023 Share Posted January 26, 2023 This is a question that I asked on their last TT120 live stream. The answer that I got was pretty inconclusive. At about 01:30 Link to comment Share on other sites More sharing options...
