dBerriff Posted July 4 Share Posted July 4 That can be done with Arduino or Pi Pico solutions. Link to comment Share on other sites More sharing options...
Rallymatt Posted July 4 Share Posted July 4 Or a switch 😁, Dave is a DC Man 1 Link to comment Share on other sites More sharing options...
dBerriff Posted July 4 Share Posted July 4 (edited) Picos and DFPlayers run off DC. 😀 DF Players will run standalone from a push button. No DCC required. We wanted a bit more control, hence the Pico, and we are testing out the system on a public layout. It is still working fine after a couple of months. Tip: if you want some good sound files take a look at the BBC sound effects library on their website. For private use their should be no issues with copyright. Edited July 4 by dBerriff 2 Link to comment Share on other sites More sharing options...
Rallymatt Posted July 4 Share Posted July 4 I got some greetings cards sound modules for a couple of spot sounds and soldered a push button switch and recorded the sound I wanted directly via the inbuilt mic (Pair of Hawker Hunters screaming over) BBC sound library is an excellent suggestion, I want a longer file for the dock scene. 👍 Link to comment Share on other sites More sharing options...
Dave the Busker Posted July 6 Author Share Posted July 6 08 has stopped working again. Tried taking it apart to get at the motor contacts, nothing seems to be bringing it back to life consistently. I know it's not the motor, it does sometimes get a good contact and spin, but something is not connecting properly. Link to comment Share on other sites More sharing options...
Dave the Busker Posted July 6 Author Share Posted July 6 I give up. Take it apart, clean contacts, check screws, clean, double and triple check - no result Accidentally give it a knock while setting it back on the track - works Link to comment Share on other sites More sharing options...
Rallymatt Posted July 6 Share Posted July 6 Have you looked the length of the screw that holds the pick up pcb? @DJBDoug found on his the screw was too long by a couple of threads and it was intermittently affecting contact 1 Link to comment Share on other sites More sharing options...
Dave the Busker Posted July 6 Author Share Posted July 6 That's where I'll likely be looking if it cuts out again. At the moment it's running, so it's something intermittent like that. 1 Link to comment Share on other sites More sharing options...
Charlie 66 Posted July 8 Share Posted July 8 On 06/07/2024 at 18:22, Dave the Busker said: I give up. Take it apart, clean contacts, check screws, clean, double and triple check - no result Accidentally give it a knock while setting it back on the track - works If in doubt, hit it with a hammer 😁 1 Link to comment Share on other sites More sharing options...
Dave the Busker Posted July 13 Author Share Posted July 13 Found myself over in Edinburgh recently, so I popped into Harburn Hobbies and picked up a couple of Metcalfe kits for the station and an Oxford Diecast TT:120 post van. 5 Link to comment Share on other sites More sharing options...
Dave the Busker Posted July 13 Author Share Posted July 13 First of the Metcalfe kits, station platform shelter and waiting room. It's wired for lighting too but I've not got it plugged into the layout's power yet. It's showing up the uneven platform surface, so some weeds will no doubt start growing around the base to hide that... 2 Link to comment Share on other sites More sharing options...
Dave the Busker Posted July 14 Author Share Posted July 14 Today’s project. Just need to let the glue set before adding the canopy glazing. I'll probably look out a taller door too as this is another N kit. I was going to watch the tennis to kill time but it looks like that might not be on for long... 2 Link to comment Share on other sites More sharing options...
Stephen-1260829 Posted July 14 Share Posted July 14 1 hour ago, Dave the Busker said: Today’s project. Just need to let the glue set before adding the canopy glazing. I'll probably look out a taller door too as this is another N kit. I was going to watch the tennis to kill time but it looks like that might not be on for long... The station is looking very nice 1 Link to comment Share on other sites More sharing options...
Dave the Busker Posted July 14 Author Share Posted July 14 Cheers @Stephen-1260829! I've got the island building finished now, and you can see how much better it fits with TT:120 with a larger door fitted. That's a Noch TT figure by the door for scale. 10 Link to comment Share on other sites More sharing options...
Dave the Busker Posted July 24 Author Share Posted July 24 Here's a new video from Hollybush. Not a whole lot of new stuff to show off, but got a day off to enjoy running the trains today. Pleased to report that the Morley controller is still running perfectly, I've had no motor issues since I switched to it. When I'm filming, operations can be quite stop-start and involve frequent direction changes to get locos in place for the shots. On my old controller, that seemed to cause no end of problems. 6 Link to comment Share on other sites More sharing options...
Dave the Busker Posted July 25 Author Share Posted July 25 Following on from @Rallymatt's thread on tiny self-contained switch and LED units for lighting brake vans and other tight spaces, here's one I tried. Needs a wee bit of lining inside the van to cut down light leaks where I don't want them, and we'll see how long the batteries last soon enough, but I'm impressed with these wee lights. 2 Link to comment Share on other sites More sharing options...
Dave the Busker Posted July 25 Author Share Posted July 25 I ordered the starter pack of 3 lights and wand to see what I made of them. I've put the other two into the station canopy where it would have been difficult to put in wired lights and be able to hide the wires. These can just be stuck into the roof with a spot of blu-tack, no wires to worry about. 2 Link to comment Share on other sites More sharing options...
david_watts1 Posted July 25 Share Posted July 25 I bought the 10 pack of lights, I have loads of magnets to make a wand, they are tiny. It will be a while before I get to use them though. 3 Link to comment Share on other sites More sharing options...
Dave the Busker Posted August 3 Author Share Posted August 3 Using @Rallymatt's circuit plan for battery powered DIY coach lighting. I'll not be putting any electricians out of work with my soldering skills, but I've got one of the trains fully lit without burning down the house! I'll put some video up on my YouTube channel later once it's dark outside. The room the railway's in doesn't have curtains that fully black out light and it's an usually bright day in Glasgow, not quite showing off the lights to full effect 3 Link to comment Share on other sites More sharing options...
Rallymatt Posted August 3 Share Posted August 3 They look great in the daylight Dave, good little project with great results 😁 1 Link to comment Share on other sites More sharing options...
Dave the Busker Posted August 3 Author Share Posted August 3 Cheers for the inspiration and sharing the circuit plans on your YouTube channel! 1 Link to comment Share on other sites More sharing options...
Dave the Busker Posted August 9 Author Share Posted August 9 Today’s project has been this Metcalfe Fire Station. It’s the first one of theirs where the size difference between the N gauge kit and my TT:120 layout has felt noticeable. Still looks ok in the scene but it’s a very tight fit for the fire engine 3 Link to comment Share on other sites More sharing options...
What About The Bee Posted August 9 Share Posted August 9 Hi @Dave the Busker Move the engine away from the firehouse a bit. Won't be so noticeable. If it is coming back to the firehouse, no lights would be on. Or away, if you do want them on! Bee Link to comment Share on other sites More sharing options...
Dave the Busker Posted August 9 Author Share Posted August 9 2 minutes ago, What About The Bee said: Move the engine away from the firehouse a bit. Aye, that's the plan, just put it close in to show the comparative sizes to illustrate if anyone else was thinking about trying this particular kit. 1 Link to comment Share on other sites More sharing options...
Rallymatt Posted August 10 Share Posted August 10 Certain N buildings of Metcalfe’s seem to be more obviously undersize for TT than others, this still looks really good though. 1 Link to comment Share on other sites More sharing options...
