96RAF Posted March 19, 2023 Share Posted March 19, 2023 Thanks for your quick reply 96RAF , the package that it came in states the following:CE/FCC Certified for Security Assurances. With Over current protection; Over power protection; Over voltage protection; Short Circuit Protection.Should I check it myself anyway as a double check ? Sounds to be a good spec but always worth doing a simple short circuit check by connecting to a length of track and placing a coin across the rails. It should self protect almost immediately, if your coin melts then user beware. You can use a multimeter to check overload voltage and over-current shut down but you may need to add in some test components like a hefty wattage resistor as a load. Link to comment Share on other sites More sharing options...
TheDonald Posted March 19, 2023 Share Posted March 19, 2023 Thanks guys! Link to comment Share on other sites More sharing options...
