candishtowers Posted April 12, 2023 Share Posted April 12, 2023 Installed an 8 pin HM7000 in my new NWR yellow class 31. Control, lights and sounds all working fine on Bluetooth mode, but switching to my ECOS DCC, control and sounds work fine, but there are no head/tail lamps - except they come on when I press Function 28 on the ECOS which is AFC or Automatic Function Control. I have re-set the decoder twice with the same results. Not a great problem as the lights do work under F28 but I was wondering if anybody had any suggestions? Link to comment Share on other sites More sharing options...
Rog RJ Posted April 12, 2023 Share Posted April 12, 2023 How are you (trying to) turning the head and tail lights on when you aren't using F28? Link to comment Share on other sites More sharing options...
96RAF Posted April 12, 2023 Share Posted April 12, 2023 F28 pulls up lights, sound - start up, background and brakes, along with random other sounds. This proves your lighting is good but why they don’t work on F0 from DCC is odd. There doesn’t appear to be anything in the decoder manual to help apart from CV29 bit1 which defines where the decoder looks to find directional lighting, but if it works in F28 then CV29 would seem OK. Link to comment Share on other sites More sharing options...
P-Henny Posted April 12, 2023 Share Posted April 12, 2023 Just in case and just to eliminate all possibilities, what is the value of CV29 when in DCC operation mode. It may not have 128 speed steps enabled which is the usual reason for F0 not working. Link to comment Share on other sites More sharing options...
candishtowers Posted April 12, 2023 Author Share Posted April 12, 2023 Thanks for your replies. Yes, I am trying to turn on the lights with F0, but with no effect.I'll have a look at your suggestion for CV29, but as I say, it's no great shakes. Cheers. Link to comment Share on other sites More sharing options...
96RAF Posted April 13, 2023 Share Posted April 13, 2023 I have an Electrotrens loco where the basic running lights do not come on until a higher Aux function light is selected. The only indications with F0 only on are the cab number panels lighting up, but if I select the higher Aux keys with F0 off I do not get running lights. 21-pin TXS installed. Link to comment Share on other sites More sharing options...
