Slipperysam1984 Posted September 13, 2012 Share Posted September 13, 2012 Hi, I'm just getting back into trains from a 10 year gap. i have some older 12 volt trains, like the Flying Scotsman. From what I have looked up, DCC puts down more power then DC. If I put a decoder in my train will this protect the motor from damage. thanks for your time Sam Link to comment Share on other sites More sharing options...
poliss Posted September 13, 2012 Share Posted September 13, 2012 Yes, once a decoder is fitted your locos will be just like any othe DCC locos. Older locos may need a more powerful decoder such as the Hornby Sapphire. Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 13, 2012 Share Posted September 13, 2012 DCC does not produce more power than DC. As the same locos with the same motors operate on either system, the power "produced" is the same as far as the loco motor is concerned. The way the power is produced is different though. DC is just a varying DC voltage with motor speed varying as the voltage varies. DCC produces power via a very high frequency pulse width modulated voltage which ends up being seen by the motor as varying DC just as if it were DC. So there is no danger that DCC will burn out older motors. In fact the reverse may be true - older motors sometimes require more power than modern motors. Consequently, as poliss says, you may need to fit a more powerful decoder to older locos so that they don't burn out the decoder. Link to comment Share on other sites More sharing options...
Gregd99 Posted September 13, 2012 Share Posted September 13, 2012 if you google "dcc stall current" you will find some info on why more powerful decoders can be (are?) needed for older motors. I have an old dockyard shunter that causes the house lights to dim when I run it no dc!! Link to comment Share on other sites More sharing options...
Flashbang Posted September 14, 2012 Share Posted September 14, 2012 Hi If a loco of any age is drawing huge amounts of current then the two most likely cases are.... 1) The motors magnet has become weak.. Replace with a suitable new one and if possible a Neodymium magnet. 2) The motors windings are on partial short circuit. In which case replace the complete motor. Many motor styles are still available or you can get a rewound motor if necessary. Link to comment Share on other sites More sharing options...
poliss Posted September 14, 2012 Share Posted September 14, 2012 Don't forget that the Hornby R8249 is only rated at 500mA with a 1Amp peak. Link to comment Share on other sites More sharing options...
