DJN Posted July 29, 2023 Share Posted July 29, 2023 Hello,I am using a Select controller that came with the Mixed Traffic train set.Its version 1.16 . POST = 20 30 03I have been able to program locomotive addresses and rate of speed change.However, the "0" key doesn't work and this number can't be entered as a part of any operation. Have tried cleaning the key , but to no avail. Will return to Hornbyif nothing further to try...My question is: After a controller reset what programming operations would l I need to repeat for each loco? Link to comment Share on other sites More sharing options...
96RAF Posted July 29, 2023 Share Posted July 29, 2023 Working in reverse…After a reset you need to do nothing to the locos as they retain their memory within the decoders.Loco zero is disable by default to prevent DC runway, but to check if it is the key itself at fault press and hold the Function key as you power it up. Release when you see 88. Then press every key in turn and see the check figures appear, including the arrow buttons and speed dial. If the 0 key is working you will see 00 on screen.Power cycle the Select to return to normal boot status.V2.0 is applied to the face-lift version and is functionally identical to v1.6. Link to comment Share on other sites More sharing options...
DJN Posted July 29, 2023 Author Share Posted July 29, 2023 Thanks for that info. RAF. The power on keys test showed that key "0" was indeed working - after a reset;to enable analogue control, the numeral 0 could be input at the Select keyboard.robot_face Link to comment Share on other sites More sharing options...
96RAF Posted July 29, 2023 Share Posted July 29, 2023 Good to hear but running loco zero is not a good idea even though possible due to possible motor damage if loco is left stationary. Link to comment Share on other sites More sharing options...
DJN Posted August 4, 2023 Author Share Posted August 4, 2023 I wanted a working key zero to initiate the CV programming sequence - after setting a CV the unit reverted to key zero disabled. Also, the forward and reverse keys operate the opposite way round to what one would expect . I should add that my set was purchased at a discount due to damaged packaging.. So thisSelect may have suffered a knock or two. Link to comment Share on other sites More sharing options...
96RAF Posted August 4, 2023 Share Posted August 4, 2023 You said you have checked and the Zero key works.You are obviously confusing loco zero with a basic zero key press.Loco Zero if disabled prevents you from entering a zero at the select loco address point. You can if you really must reset the Select (see the manual) and choose to have loco zero enabled (definitely not recommended). To enter programming mode you long press Select, then input key 0 of 00, then enter the CV number to change, noting if a 3 digit number when you press 1 (for hundreds ) or 2 (for hundreds) the screen flips to allow you enter the tens and digits values. Then you enter the new value for the CV. You need to download the manual for v1.5 AND tge appendix for v1.6/2.0, else you are guessing what to do next and getting it wrong. Link to comment Share on other sites More sharing options...
DJN Posted August 6, 2023 Author Share Posted August 6, 2023 A Select manual and its v.1.6 addendum were supplied the Mixed Traffic rain set. Key zero worked in test mode and once for programming a CV . But it has now reverted to its former condition. Ie nothing appears on the display if it is used when assigning a loco address - so addresses such as "10" or "20" can't be input.I may return it to Hornby for inspection and a possible fwr re-flash.. Link to comment Share on other sites More sharing options...
96RAF Posted August 6, 2023 Share Posted August 6, 2023 Try a Select unit reset per the manual.It maybe you are pressing the 1 or 2 for too long and it thinks it has gone into hundreds, tens and units mode, when of course it can only accept loco addresses 1 to 59. Link to comment Share on other sites More sharing options...
