Johnathan-346380 Posted May 29 Share Posted May 29 I want to re-number and rename the Class 50 using Railtec transfers. Has anyone done this already to any of their locomotives? How easy is it to remove the existing locomotive numbers any tips or suggestions? Link to comment Share on other sites More sharing options...
Silver Fox 17 Posted May 29 Share Posted May 29 3 minutes ago, Johnathan-346380 said: I want to re-number and rename the Class 50 using Railtec transfers. Has anyone done this already to any of their locomotives? How easy is it to remove the existing locomotive numbers any tips or suggestions? I only paint over the original number but Rallymatt has a video of removing the printed ones. Link to comment Share on other sites More sharing options...
atom3624 Posted May 29 Share Posted May 29 You have to be very careful when renumbering, to ensure you only see the replacement numbering, not the 'mess you left behind'. It appears they send the complete number, for example if the TOPS number on the locomotive is 50 012 and you want to change to 50 022, you'll get the complete '50 022'. This would assume same font and spacing, but overlapping numbers would be visible. I generally remove the individual number(s) required and replace them - combination of solvent rubbing, scraping and a little careful scratching. The 'art' is in trying to keep the removal only to the number - toothpick, very fine pointed implement, etc. Also, you must ensure you do not remove any of the base paint from underneath the tampo printed TOPS number you're removing. After all of this, once you've replaced the number and it's dried, most sites recommend to 'lightly dust' with lacquer / varnish to seal it - they can flake off again if not done. Probably better to practice this separately on an old body if you have one. Main thing is preparation is the most important thing. If you do finish with lacquer / varnish I strongly recommend you practice this on something you no longer need - it will run if you use one drop too much. As stated, there are plenty of 'How To' videos - I would suggest watching several different ones, as many skilled modellers have different ways of doing the same thing - some ideas may be better than others. Al. 1 Link to comment Share on other sites More sharing options...
Rallymatt Posted May 29 Share Posted May 29 I renumbered all my TTA tankers. Using toothpaste and Sodium Bicarbonate as a paste. It’s not damaging to paint or plastics, most people have it in the house too. NOTE it is an abrasive; so although it’s easy to control, ie you won’t burn through the paint below, it can leave a trace of ‘polishing’. That could be removed with a touch up of clear matt varnish or many modellers recommend using gloss vanish on the base, apply the transfer and then matt varnish over. Chemical methods of removing numbers etc can have all sorts of effects on paint and plastics. The yellow of the wasp stripes on the 08 reacted very badly to a tiny amount of thinners, it looked more like I had use Nitromors! I would strongly recommend testing first before going all in. 4 Link to comment Share on other sites More sharing options...
Johnathan-346380 Posted yesterday at 08:45 Author Share Posted yesterday at 08:45 Thanks for all the advice. I eventually used nail polish remover brushed carefully on each individual transfer and then wooden manicure sticks to rub it off. 5 Link to comment Share on other sites More sharing options...
Irishmail Posted 23 hours ago Share Posted 23 hours ago What's the story with the Eastfield scottie dog on the hoover? 🙂 Link to comment Share on other sites More sharing options...
Johnathan-346380 Posted 22 hours ago Author Share Posted 22 hours ago 4 minutes ago, Irishmail said: What's the story with the Eastfield scottie dog on the hoover? 🙂 I’m modelling Rannoch station on the West Highland line. The only time the 50’s were present on the line was during a Pathfinder tour (50031 & 50049). A Scottie dog was added for the tour. Once HM7000 allows double heading I will add 50031. 3 Link to comment Share on other sites More sharing options...
