Captain_Francisco. Posted November 29, 2012 Share Posted November 29, 2012 Are the locomotive & accessory addresses interchangeable from the "Select" to the "Elite," and vice versa? i.e. If you have already programmed a loco as no.7, does it, the loco, react as no.7 no matter the controller plugged in, or is it necessary to re-programme from controller to controller? I am at present, particularly interested in the Hornby controllers, but any more general information always of interest, and appreciated. Link to comment Share on other sites More sharing options...
Rog RJ Posted November 29, 2012 Share Posted November 29, 2012 Once a decoder is programmed with an address, that address is usable on any DCC system but there can be problems if a loco is given an address which isn't in the possible range of addresses on the other controller. For instance, it would be impossible to use a loco with the address 1111 on the Select which can only use loco addresses from 1 to 59. Link to comment Share on other sites More sharing options...
Captain_Francisco. Posted November 29, 2012 Author Share Posted November 29, 2012 Thanks Roq(RJ) Much appreciated. Link to comment Share on other sites More sharing options...
Gregd99 Posted November 29, 2012 Share Posted November 29, 2012 I am not an expert on the select but there are some limitations with the accessory decoder wrt to the elite. the select has accessory decoder addresses numbering from 60 (I think) upwards. The elite starts at 1. I am not sure if elite #1 is select #60 (or 61) or if elite #61 = select #61. Link to comment Share on other sites More sharing options...
96RAF Posted November 30, 2012 Share Posted November 30, 2012 Francisco The accessory decoder manual goes a long way to explaining the Select/Elite addressing differences: https://www.hornby.com/downloads/digital-instruction-manuals/ There is also a difference in address interpretation depending on the Select firmware state - check with Hornby Customer Support as it can be updated by them free of charge. Rob Link to comment Share on other sites More sharing options...
Captain_Francisco. Posted December 3, 2012 Author Share Posted December 3, 2012 Thanks Gregd99 & RAFHAAA96th. Downloading as we speak! Franci. Link to comment Share on other sites More sharing options...
