Captain_Francisco. Posted December 11, 2012 Share Posted December 11, 2012 Hornby markets the R 8241 as a "Digital Power Track," and the R 8206 simply as a "Power Track," which only appears in the analogue DC equipment section. They look to me to be exactly the same animal, at least superficially. Are they in fact the same, and interchangeable. Further, the R 8242 "Digital Power Connecting Clip," and R 602 "Power connecting clip (Analogue)," look the same on the outside; again, are they the same "animal," and usable on either system. I haven't had the courage to try "cross breed" them and try, in case something "has an expensive meltdown." If however they are, I have an immediate solution to a minor problem. I am not an expert with the soldering iron, and only the firmly fixed in place pieces eventually get "the treatment." On any other part of the layout, still undergoing design and "sudden rush of blood to the brain" modifications, I prefer to use the easily removeable/repositionable type items. Link to comment Share on other sites More sharing options...
poliss Posted December 11, 2012 Share Posted December 11, 2012 The DC variety contains a capacitor which interferes with the DCC pulses. The capacitors can be removed quite easily. Someone on the forum should be able to tell you how they did it. Link to comment Share on other sites More sharing options...
Captain_Francisco. Posted December 11, 2012 Author Share Posted December 11, 2012 Thanks Poliss Link to comment Share on other sites More sharing options...
96RAF Posted December 11, 2012 Share Posted December 11, 2012 The clips can be sprung open with a small screwdriver then you can just clip off the capacitor, reclose the clip and use on DCC. Rob Link to comment Share on other sites More sharing options...
Captain_Francisco. Posted December 11, 2012 Author Share Posted December 11, 2012 Thanks RAFHAAA96th. I shall investigate in the morning. Link to comment Share on other sites More sharing options...
malang66 Posted December 14, 2012 Share Posted December 14, 2012 Captain_Francisco. said: Hornby markets the R 8241 as a "Digital Power Track," and the R 8206 simply as a "Power Track," which only appears in the analogue DC equipment section. They look to me to be exactly the same animal, at least superficially. Are they in fact the same, and interchangeable. Further, the R 8242 "Digital Power Connecting Clip," and R 602 "Power connecting clip (Analogue)," look the same on the outside; again, are they the same "animal," and usable on either system. I haven't had the courage to try "cross breed" them and try, in case something "has an expensive meltdown." If however they are, I have an immediate solution to a minor problem. I am not an expert with the soldering iron, and only the firmly fixed in place pieces eventually get "the treatment." On any other part of the layout, still undergoing design and "sudden rush of blood to the brain" modifications, I prefer to use the easily removeable/repositionable type items. THANKS FOR ASKING THIS QUESTION, AS I WAS IN THE SAME BOAT AS YOU AND WAS GOING TO POST THIS QUESTION, SO THIS HAS ANSWERED ALL MY PROBLEMS NOW, SO I TO CAN CONTINUE WITH MY LAYOUT DESIGN AS LIKE YOU I'M NOT HOT WITH A SOLDERING IRON, PLUS I'VE GOT MY MAIN TWO LOOPS IN PLACE BUT STILL DESIGNING THE GOODS YARD AND UPPER LEVEL.... Link to comment Share on other sites More sharing options...
Captain_Francisco. Posted December 14, 2012 Author Share Posted December 14, 2012 Only a pleasure: indeed, this Forum has proved to be, "only a pleasure." The few questions that I have had, that have been "bothering" me, and that I have posted as threads, have been royally answered and explained. Some technical forums can appear like an "ego trip for the cognoscenti;" not this one! It really welcomes all, and strives to be helpful. Well done & thanks to all you "Hornyby'ists," a sterling breed, and appreciated. Keep up the good work! Link to comment Share on other sites More sharing options...
