andy5898 Posted January 9, 2013 Share Posted January 9, 2013 Can anyone recommend Signals for my layout which will connect to my Hornby Elite controller. Do I need a decoder for them to attach through the Elite? If I need a decoder can anyone recommend any Hornby signals which I can just connect up the old fashioned way. Cheers Link to comment Share on other sites More sharing options...
BigNoj Posted January 9, 2013 Share Posted January 9, 2013 andy5898 said: Can anyone recommend Signals for my layout which will connect to my Hornby Elite controller. Do I need a decoder for them to attach through the Elite? If I need a decoder can anyone recommend any Hornby signals which I can just connect up the old fashioned way. Cheers Link to comment Share on other sites More sharing options...
BigNoj Posted January 9, 2013 Share Posted January 9, 2013 Check out the Train-Tech DCC signals. No wiring needed and they have an in built decoder. Bit dear but well worth it. Link to comment Share on other sites More sharing options...
Sidders100 Posted January 12, 2013 Share Posted January 12, 2013 BigNoj can you advise if the train-tech signals are ok to work with a select controller? Im reading that do get the most out of this you need an elite, but dont really want to shell out 200 sheets. Link to comment Share on other sites More sharing options...
wiggy25 Posted January 12, 2013 Share Posted January 12, 2013 Yes they will work OK with the Select. You just connect them to the track put a bit of wire between the two "learn" contacts type in the address you want, so on the Select press the ACCY button then type in the address you want then press the left or right arrow, signal programmed with the address. You could give it the same address as that of the point, so when the point is activated the signal will change at the same time. If you Google train tech DCC it will take you to the web site and you can download the instructions for the signals. Cheers Ian Sidders100 said: BigNoj can you advise if the train-tech signals are ok to work with a select controller? Im reading that to get the most out of this you need an elite, but dont really want to shell out 200 sheets. Link to comment Share on other sites More sharing options...
