Desperate_Dave Posted May 8, 2013 Share Posted May 8, 2013 I have a Select controller and one of my locomotives moves in the opposite direction to the green arrow. I have tried correcting this by following the instructions on Page 12 of the manual. It says 'Press and hold the unlit direction key and the LCD will display either FD or RD' but it doesn't - nothing happens. Has anyone had this problem please? Link to comment Share on other sites More sharing options...
Rog RJ Posted May 8, 2013 Share Posted May 8, 2013 The method of changing the default direction was changed. In Select version 1.2 the Decoder Default Direction is now set with a two key operation. This is now achieved by pressing and holding the “0” and one of the Direction Arrow buttons at the same time for 3 seconds. Link to comment Share on other sites More sharing options...
Desperate_Dave Posted May 8, 2013 Author Share Posted May 8, 2013 Thanks a lot - that worked fine. Link to comment Share on other sites More sharing options...
HooliganHedgehog Posted April 4, 2014 Share Posted April 4, 2014 Thanks Rog (RJ), Spent hours trying and re-trying, checking connections, wiring .............. In desperation turned to this Forum and found your posting. Thank you, thank you. Link to comment Share on other sites More sharing options...
JonathanMC Posted September 14, 2014 Share Posted September 14, 2014 At least Hornby shoulld correct the online copy of the manual, even if the printed versions were too late to correct before sending out with train sets. Link to comment Share on other sites More sharing options...
idlemarvel Posted September 14, 2014 Share Posted September 14, 2014 Agreed. Select 1.2 has been around for ages, Hornby should have updated the online version of the manual by now.There is a posting by Hornby back in 2012, link here:https://www.hornby.com/forum/select-v12-firmware-changes-%2812-30-03%29-/ Worth reading the whole post if you have a Select as it also talks about power, and accessory decoder addressing, both of which are common and recent issues on this forum. Link to comment Share on other sites More sharing options...
Yelrow Posted September 14, 2014 Share Posted September 14, 2014 Desperate, dont know what version you have of select, but just had mine updated free by hornby, it was 2 versions out of date, john Link to comment Share on other sites More sharing options...
JohanC Posted September 14, 2014 Share Posted September 14, 2014 yelrow,How do you tell the version of the Select and how do Hornby update?John Link to comment Share on other sites More sharing options...
idlemarvel Posted September 14, 2014 Share Posted September 14, 2014 According to that posting (and my Select) the digits 12, 30, 03 will now be displayed on start up if you have v1.2 which is the latest version. If you don't you have to send the Select back to Hornby in Margate, from same posting:<quote>You can send your Selects in for an update; this is free of charge. Please attach a covering letter explaining the issue and send to:FAO - Repairs DeptHornby HobbiesWestwoodMargateKentCT9 4JX <end quote>BTW if the link I included doesn't work just search for select v1.2 in the forum search bar. Link to comment Share on other sites More sharing options...
JohanC Posted September 14, 2014 Share Posted September 14, 2014 Many thanks. I'm still on 1.1. Will send them off.BTW is there any difference between the Select and the Select Walkabout. They appear to be exactly the same. Link to comment Share on other sites More sharing options...
idlemarvel Posted September 14, 2014 Share Posted September 14, 2014 As you can use an "ordinary" Select as a Walkabout with an Elite I guess they are the same. The price difference is because the Walkabout does not come with a transformer as it does not need any external power. Link to comment Share on other sites More sharing options...
JohanC Posted September 14, 2014 Share Posted September 14, 2014 Thanks. Guess you are right.RegardsJohn Link to comment Share on other sites More sharing options...
RDS Posted September 14, 2014 Share Posted September 14, 2014 They are the same except as you say, the walkabout does not come with a transformer but it does come with a (special) network lead. Link to comment Share on other sites More sharing options...
