rugbyboys Posted July 15, 2013 Share Posted July 15, 2013 Hi I have a new Hornby DCC Sound fitted Loco its only a couple of months old but over the last few weeks it has stopped responding the controller correctly it started off by having a long delay to commands like blowing the whistle while running but now it has got so bad the only way that I can stop the loco is by hitting the E stop button, this is obviously not correct any thoughts lads. Link to comment Share on other sites More sharing options...
Rog RJ Posted July 15, 2013 Share Posted July 15, 2013 The first thing I would try is resetting the controller. Link to comment Share on other sites More sharing options...
Rog RJ Posted July 15, 2013 Share Posted July 15, 2013 Also, are the wheels and track clean? Link to comment Share on other sites More sharing options...
rugbyboys Posted July 15, 2013 Author Share Posted July 15, 2013 Hi, Yes Track and controller all ok I have several other DCC Sound Loco and they all work ok on the same track, also if I turn the sound off the loco performs as it should. Link to comment Share on other sites More sharing options...
RDS Posted July 15, 2013 Share Posted July 15, 2013 @rugbyboys If you are able to, I suggest you take it back to the supplier because if your other Loco's work OK, it seems that something is wrong with it and it should be well within the warranty period. Link to comment Share on other sites More sharing options...
poliss Posted July 15, 2013 Share Posted July 15, 2013 Have you tried resetting the decoder? Link to comment Share on other sites More sharing options...
