AlexPW Posted August 20, 2013 Share Posted August 20, 2013 A simple yes & no answer for a simple person (who would like software that just installs)as to whether RM will run on the above plateforms? Then I can decide to go with the old laptop or the new desktop with the least likely number of problems to encounter before I get it working! Perhaps I am unlucky, but past experience indicates,ask first before hitting the install button! Cheers Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 20, 2013 Share Posted August 20, 2013 Short answer - yes. Long answer - and there are separate drivers and installation instructions for each included with the documentation. Link to comment Share on other sites More sharing options...
AlexPW Posted August 20, 2013 Author Share Posted August 20, 2013 Thanks, So to put you on the spot, which one would you pick if you had the option all things considered? So I don't repeat the "Oh no not again" moment! Cheers Link to comment Share on other sites More sharing options...
RB51 Posted August 21, 2013 Share Posted August 21, 2013 AlexPW said: Thanks, So to put you on the spot, which one would you pick if you had the option all things considered? So I don't repeat the "Oh no not again" moment! Cheers Link to comment Share on other sites More sharing options...
RB51 Posted August 21, 2013 Share Posted August 21, 2013 RogerB said: AlexPW said: Thanks, So to put you on the spot, which one would you pick if you had the option all things considered? So I don't repeat the "Oh no not again" moment! Cheers Link to comment Share on other sites More sharing options...
RB51 Posted August 21, 2013 Share Posted August 21, 2013 That's the second time today my post seems not to have loaded. I will check both tomorrow and re-submit if still not showing. See, I told you I was no good with computers!!!! R- Link to comment Share on other sites More sharing options...
RDS Posted August 21, 2013 Share Posted August 21, 2013 @AlexPW I use RM on 2 computers, 1 is XP and the other Windows 7. Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 21, 2013 Share Posted August 21, 2013 AlexPW said: Thanks, So to put you on the spot, which one would you pick if you had the option all things considered? So I don't repeat the "Oh no not again" moment! Cheers As the performance of RM is independent of operating system, the one you use is irrelevant. Therefore use the one with which your are most comfortable. For me, that is W8 with W7 very close behind. Link to comment Share on other sites More sharing options...
