roystrains Posted September 7, 2013 Share Posted September 7, 2013 I have upgraded from Select DCC to e.link and whereas I could previously run my non converted locos on Select under the "0" setting I don't seem to be able to do this on e.link. Would there be any harm to system if I also connected the Select controller through an extra digital power track so that I could run non converted locos through this ? Link to comment Share on other sites More sharing options...
Graskie Posted September 7, 2013 Share Posted September 7, 2013 It's possible to run analogue locos on DCC track, but not advisable because of the possibility of motor burn-out, especially when stationary. You should also keep DC and DCC track totally separate or isolated from each other. Link to comment Share on other sites More sharing options...
poliss Posted September 7, 2013 Share Posted September 7, 2013 Is it possible with eLink though? Link to comment Share on other sites More sharing options...
Graskie Posted September 7, 2013 Share Posted September 7, 2013 That's a good point, poliss. I'm not into eLink, but I suppose, not being a controller in itself, you probably can't call up loco 0 from RM. Link to comment Share on other sites More sharing options...
Barry1946 Posted September 7, 2013 Share Posted September 7, 2013 Graskie said: That's a good point, poliss. I'm not into eLink, but I suppose, not being a controller in itself, you probably can't call up loco 0 from RM. Link to comment Share on other sites More sharing options...
Barry1946 Posted September 7, 2013 Share Posted September 7, 2013 As I understand it, on straight forward DCC control, the unconverted loco is receiving a signal all the time but cannot use it to move. This signal will cause overheating and the loco motor WILL burn out. Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 7, 2013 Share Posted September 7, 2013 Concerning the Select part of the question, no you cannot connect it too. It is only possible to have one DCC controller on any layout. You can only connect a second one to a completely isolated layout. This is done on very large layouts where the separated sections are called different power districts. And then a power booster is often used to run the second power district. Link to comment Share on other sites More sharing options...
roystrains Posted September 9, 2013 Author Share Posted September 9, 2013 Fishmanoz said: Concerning the Select part of the question, no you cannot connect it too. It is only possible to have one DCC controller on any layout. You can only connect a second one to a completely isolated layout. This is done on very large layouts where the separated sections are called different power districts. And then a power booster is often used to run the second power district. Link to comment Share on other sites More sharing options...
roystrains Posted September 9, 2013 Author Share Posted September 9, 2013 Thanks Fishmanoz Link to comment Share on other sites More sharing options...
RDS Posted September 9, 2013 Share Posted September 9, 2013 @roystrains I know this does not answer your question but I believe the safest way forward is to gradually fit DCC decoders to your DC loco's but in the meantime if you want to run them, create a completely separate track layout, powered by a DC controller. As has been stated above, it is not advisable to run non DCC loco's on a DCC layout and you can only run one at once anyway. Link to comment Share on other sites More sharing options...
