Jsdcs07 Posted October 27, 2013 Share Posted October 27, 2013 Hi I am new and just after some help. I have got a Lima 50 Class and looking at installing the hornby R8249 decoder. I understand the best part of the installation, the red & black cable goes to the pick up and the orange & Grey goes to the motor connections. Please correct if I am wrong. Now on the 50 Lima I have a capacitor inbetween the motor, do I leave the or remove the capacitor. I am guid it say to remove it but I would like to know if I need to and why. See the link. http://www.rmweb.co.uk/dcc/Lima.htm Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 27, 2013 Share Posted October 27, 2013 Remove it. The capacitor is there to suppress interference to radio and TV signals nearby for DC running. It can degrade DCC signal, and the 8249 has suppression anyway, so not needed for DCC. Link to comment Share on other sites More sharing options...
Gregd99 Posted October 27, 2013 Share Posted October 27, 2013 if the capacitor is between the decoder and the track (red/black wires) it can degrade the dcc signal and cause all sorts of unexpected behaviour that will send you prematurely grey. if the cap is between the decoder and the motor (orange/grey wires) this is just a normal PWM control signal and I would think that there is no problem to leave it in place. Happy to be corrected by others with more detailed knowledge. Link to comment Share on other sites More sharing options...
Rog RJ Posted October 27, 2013 Share Posted October 27, 2013 Gregd99 said: if the capacitor is between the decoder and the track (red/black wires) it can degrade the dcc signal and cause all sorts of unexpected behaviour that will send you prematurely grey. if the cap is between the decoder and the motor (orange/grey wires) this is just a normal PWM control signal and I would think that there is no problem to leave it in place. Happy to be corrected by others with more detailed knowledge. There are some makes of decoder which don't work very well if the capacitors are left on the motor (the capacitor can affect the BEMF feedback sensing) but Hornby decoders, in my experience, aren't affected at all. In the case of the OP, I would remove the capacitor as it's not needed when a decoder is fitted. Link to comment Share on other sites More sharing options...
Jsdcs07 Posted October 28, 2013 Author Share Posted October 28, 2013 Thank's for the help, an i am quite sure that as i upgrade the other loco's i will be asking more questions. I am starting with the Lima 50 class as it was the cheapest that i have bought. If is goes wrong not to much of a costly mistake, LOL. Next on the list will be a Hornby Top link 58 class 58. but i will do the 50 first and see how i get on. Another other advice would be appreciated. Link to comment Share on other sites More sharing options...
Michael_A Posted October 29, 2013 Share Posted October 29, 2013 The capacitor across the motor reduces RF inteference by supressing the spark fromm the brushes on the commutator as the motor armature rotates. So without it not only would you get RF interference, you would potentially burn brushes away more quickly, and could cause burning on the armature. However, as this suppression is effectively built into the DCC decoder, you can safely remove it, but if you do and for whatever reason in the future you remove the decoder, you should replace it. I tend to leave them in after fitting a decoder and only remove them if I notice any operating issues, especially at low speeds. (which out of 50 locos I have chipped is yet to happen) Capacitors that are effectively straight across the track itself must always be removed when using DCC. Link to comment Share on other sites More sharing options...
Jsdcs07 Posted October 30, 2013 Author Share Posted October 30, 2013 Ok Thanks Michael, so really just leave it in and if getting problems / interference then remove. I could be being thick but "Capacitors that are effectively straight across the track itself must always be removed when using DCC." dont get this, could you explain but i could be not reading this right. thanks Link to comment Share on other sites More sharing options...
pidder Posted October 30, 2013 Share Posted October 30, 2013 If the capacitor is not in the way of refitting the model body, just disconnect one wire, make sure it's out of the way when you re-assemble... Link to comment Share on other sites More sharing options...
Michael_A Posted October 30, 2013 Share Posted October 30, 2013 Some locos have suppressor capacitors also across the pickups. These need to be remoeved as they are effectively straight across the track, whereas the capacitor across the motor is isolated from the track by the decoder. Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 30, 2013 Share Posted October 30, 2013 With DC, pickups are connected to the motor, so a capacitor across one is also across the other, although I get the point as to where it might be mounted and where you do your disconnections to fit a decoder. A more typical capacitor across the track is the one fitted to a DC power track. It must be removed to use it for DCC. The reason is simple. Capacitors vary in "resistance" with frequency. At DC, they are open circuit, and at very high frequency they are a short circuit. DCC signals are quite high in frequency, so a capacitor across the track effectively shorts the signal out. Link to comment Share on other sites More sharing options...
Jsdcs07 Posted November 4, 2013 Author Share Posted November 4, 2013 Hi all, just an update. I fitted the decoder to the lima 50 class on Saturday afternoon, wow that was easy. all hard wired in and look clean and tidy. Took all of 30 min's to do. I left the white capacitors in-between the motor hook ups and has not made any problems. Then tested her. To me top speed was improved and also better shunting capability. then i started to play with the acceleration and deceleration setting, I can see that when i got a loco on its own i can set it to stop feraly quickly but how ealsy i can change if got lots of weight behind i set the acceleration and deceleration to a longer time. Over all i hapy with how the install went and the benfit to doing the DCC. will now be getting more for the other loco. Link to comment Share on other sites More sharing options...
