scotty27 Posted January 2, 2014 Share Posted January 2, 2014 Version 155 of Railmaster gives the option of removing the button arrows, I would like to remove these arrows, But as I have never used the ini file (although I know how to access it) as I do not want to delete something I should not, I would appreciate some guidance in the deleting procedure Link to comment Share on other sites More sharing options...
RDS Posted January 2, 2014 Share Posted January 2, 2014 scotty@27 The .ini file is contained within the RailMaster folder, called RailMaster.ini To be on the safe side make a copy of the file by right clicking on it, select Copy and then paste. This will create a copy that you can re-instate, just in case something goes wrong. The easiest way to edit this file is probably with Notepad. Open the RailMaster folder, Right click on the RailMaster.ini file and select open with Notepad. Add a new line to the end of the text file that opens as follows: Point button arrows=0 (Press enter after entering) Then click on file in the header line and select save. This does work, I have removed the point arrows on my system. Link to comment Share on other sites More sharing options...
scotty27 Posted January 2, 2014 Author Share Posted January 2, 2014 Thanks RDS Its worked for me too Link to comment Share on other sites More sharing options...
96RAF Posted January 3, 2014 Share Posted January 3, 2014 Amending the .ini file is fully explained in the manual update that comes with v1.55 Link to comment Share on other sites More sharing options...
