Shadow.Monk Posted June 6, 2011 Share Posted June 6, 2011 Hi Hornby Forums! I am going to be getting a few models, unfortunatley they are unboxed. What do you reccomend I do with unboxed locomotives to make sure that they don't get damaged and that they are well taken care of? Thanks for the help :) ShadowMonk Link to comment Share on other sites More sharing options...
poliss Posted June 7, 2011 Share Posted June 7, 2011 I use foam trays. Not the stiff white foam, but the grey foam you'd finf cameras packed in.-----------------------------Get off the line Bobby. Link to comment Share on other sites More sharing options...
bocaj Posted June 7, 2011 Share Posted June 7, 2011 I use Shoe boxes with this bouncy fome stuff (not sure what it's called!)-----------------------------------------------------------------Bechio has done it again for leeds, right into the top corner, Leeds have won the game Link to comment Share on other sites More sharing options...
DMU mad Posted June 7, 2011 Share Posted June 7, 2011 I use bubble wrap (the one with smaller bubbles), then put them in an old box. this keeps them clean and undamaged! Link to comment Share on other sites More sharing options...
LCDR Posted June 7, 2011 Share Posted June 7, 2011 There is a chemical in bubble wrap that will over time attack certain plastics and paint finishes if in direct contact. The recommended material to put next to the model is acid free tissue paper, then use a cushioning. Some foamed plastic / rubber materials will deteriorate with age and if these are in direct contact may also cause damage over time. Link to comment Share on other sites More sharing options...
Bulleidboy Posted June 7, 2011 Share Posted June 7, 2011 At most of the model railway shows I have attended, there is normally someone selling boxes for loco's. I recall they come in three sizes and are not expensive. However I have have found that when storing, for example a Bulleid Pacific, it can be a bit tight once you have added the appropriate packing. Shadow.Monk said: Hi Hornby Forums! I am going to be getting a few models, unfortunatley they are unboxed. What do you reccomend I do with unboxed locomotives to make sure that they don't get damaged and that they are well taken care of? Thanks for the help :) ShadowMonk Link to comment Share on other sites More sharing options...
Merry Hampton Posted June 7, 2011 Share Posted June 7, 2011 Thanks for that. I have just started to use bubble wrap in my storage trays because the quarter-inch thick foam rubber I've used (with no problems so far) for years has become difficult to find and is now very expensive when you do find it. Bubble wrap is usually thrown away; now I know why! LC&DR said:<div class="previousPost">There is a chemical in bubble wrap that will over time attack certain plastics and paint finishes if in direct contact. The recommended material to put next to the model is acid free tissue paper, then use a cushioning. Some foamed plastic / rubber materials will deteriorate with age and if these are in direct contact may also cause damage over time. </div> Link to comment Share on other sites More sharing options...
Cornish Triang Paul Posted June 8, 2011 Share Posted June 8, 2011 Ordinary foam in a box is considered the best. It does noy leak chemicals or turn to dust and will protecet those super detail bits. Different types are readily found so you can pick and choose what grade/size/thickness etc. More than one loco can then be stored in a box. There are several suppliers of repro. boxes or universal ones but unsure if they have any packing with them.-----------------------------------------------------------------No such thing as bad weather, just a bad choice of clothing...........................CO-TR-P Link to comment Share on other sites More sharing options...
