gilbo2 Posted March 30, 2014 Share Posted March 30, 2014 I just tried running RM, first time since the clocks changed to BST. I now get the error "it appears that the date setting or format on your computer are not set correctly. Please ensure the date format is set to dd/mm/yyyy." .....with the result its back to "Evaluation mode". I'm running in Windows 8.1 As a temporary fix I disabled "Automatically adjust clock for Daylight Saving Time" in windows time zone settings and then manually added the hour. Railmaster now works again but how can I get it to work with Windows setup to adjust the clock itself? Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted March 30, 2014 Share Posted March 30, 2014 Daylight saving in Windows does not affect the way RailMaster's clock works. It is important that the date format in Windows is the default dd/mm/yyyy for short date formats on an English system. Link to comment Share on other sites More sharing options...
gilbo2 Posted March 30, 2014 Author Share Posted March 30, 2014 HornbyRailMasterSupport said: Daylight saving in Windows does not affect the way RailMaster's clock works. It is important that the date format in Windows is the default dd/mm/yyyy for short date formats on an English system. I can confirm that windows is still set to dd/mm/yyyy I even tried resetting it to make sure. As earlier post, a temporary fix is to disable "Automatically adjust clock for Daylight Saving Time" in windows time zone settings and then manually added the hour. This seems very strange. Link to comment Share on other sites More sharing options...
96RAF Posted March 30, 2014 Share Posted March 30, 2014 dgilbert2 said: I can confirm that windows is still set to dd/mm/yyyy I even tried resetting it to make sure. As earlier post, a temporary fix is to disable "Automatically adjust clock for Daylight Saving Time" in windows time zone settings and then manually added the hour. This seems very strange. Just tried mine - RM AOK. Cyprus is GMT + 2 but BST swap over day is same as UK. Link to comment Share on other sites More sharing options...
gilbo2 Posted March 30, 2014 Author Share Posted March 30, 2014 Resolved! Having checked Windows, everything was/is correctly set up in terms of UK date format etc etc but Railmaster would still not start without dropping into Evaluation mode ever since BST started. (with auto daylight adjustment ticked) I therefore felt that this was some strange license issue so I "unregistered" RM and "re-registered". BINGO! all sorted, with Windows set to automatically adjust for day light saving. Have to see what happens in October :-) A strange incompatibility somewhere on my system but all sorted now!? Link to comment Share on other sites More sharing options...
Graskie Posted March 30, 2014 Share Posted March 30, 2014 It's just a matter of time, dg. Link to comment Share on other sites More sharing options...
gilbo2 Posted March 30, 2014 Author Share Posted March 30, 2014 Graskie said: It's just a matter of time, dg. Quite happy for a long warm summer now. Dont want October too quick :-) Link to comment Share on other sites More sharing options...
