CatmanStu Posted June 8, 2014 Share Posted June 8, 2014 My elink stopped working after months of service. The green led flashes and that is it. I also own an early DCC controller and this works fine. So come on Hornby whats going on. Link to comment Share on other sites More sharing options...
96RAF Posted June 8, 2014 Share Posted June 8, 2014 Are you using your eLink with Railmaster (stupid question as there are no other options really).Therefore report the snag in via RM built in facilty (part of help menu pull down) and it will post all the necessary files to RM support for them to analyse.RM support is very good and will respond quickly Link to comment Share on other sites More sharing options...
Yelrow Posted June 8, 2014 Share Posted June 8, 2014 Catmansu, hi, welcome to the forum.As usual,RAF96, is spot on, Horby, are able to monitor your elink, and can call down the files to look at fault. The built in facility, is there for that purpose, good luck, john Link to comment Share on other sites More sharing options...
Fishmanoz Posted June 8, 2014 Share Posted June 8, 2014 Hi Stu, if your early DCC controller is a Select, try swapping the power supplies between them and see if the eLink works again and the Select doesn't. See on recent threads here about the possibility that newer 1 Amp supplies may be faulty and this would be a good test using the Select's presumably good supply. Link to comment Share on other sites More sharing options...
CatmanStu Posted June 17, 2014 Author Share Posted June 17, 2014 Well it is still broken, Hornby repied to my query with a question about the green light, since then nothing.I replied to Hornby over a week ago and no response.I have ordered a NCE Powercab. Link to comment Share on other sites More sharing options...
CatmanStu Posted June 17, 2014 Author Share Posted June 17, 2014 I use the 4amp PSU. Link to comment Share on other sites More sharing options...
CatmanStu Posted June 24, 2014 Author Share Posted June 24, 2014 Hi gang, Very pleased to report my elink is on the way to the repair shops.Confidence restored in Hornby. Link to comment Share on other sites More sharing options...
CatmanStu Posted July 2, 2014 Author Share Posted July 2, 2014 Thanks Hornby. Recieved a replacement today, and I am very happy with the service I recieved from the service dept. Sorry about the bold text.Stuart Link to comment Share on other sites More sharing options...
