Graham1 Posted June 27, 2014 Share Posted June 27, 2014 Hello and I'm sorry if the heading sounds confusing but here's the problem. I have a loco with an unknown DCC address (don't ask!) and I am trying to figure out how to change this 'unknown' address so that I can reprogram it with my Hornby Select or even if this is possible. It appears from my little use of the Select and reading of the manual that it assumes that all decoders are set to 03 but you have the ability to change this address. The thing I do know is that the address of this particular loco is not 03.So can anyone tell me if I can get the Select to recognise the loco so that I can give it a 'Known' address - is there a function on the Select to just zero the decoder and start again.Sorry if this sounds so basic but I'm not used to using the Select as a DCC controller.Any help much appreciated.Graham Link to comment Share on other sites More sharing options...
poliss Posted June 27, 2014 Share Posted June 27, 2014 Did you just buy the loco or did you just forget the address? Link to comment Share on other sites More sharing options...
Graskie Posted June 27, 2014 Share Posted June 27, 2014 You don't neccessarily need to know what the current loco ID is. Just program it to whatever number you want, subject to the lower limitation in numbers compared to the Elite. Then try to run it. With luck it should work. Link to comment Share on other sites More sharing options...
Graham1 Posted June 27, 2014 Author Share Posted June 27, 2014 Oh OK, so if I place it on the programming track, 03 automatically appears as the default address, change that to whatever address I want it to be (within reason) and press select again - is that correct? Link to comment Share on other sites More sharing options...
Graham1 Posted June 27, 2014 Author Share Posted June 27, 2014 That's it, got it and it works a treat!! Excellent, thank you so much for your help, that's really appreciated. Link to comment Share on other sites More sharing options...
Graskie Posted June 27, 2014 Share Posted June 27, 2014 Very pleased to have helped, Graham. Try the forum again if you have any further problems, as we all do. Link to comment Share on other sites More sharing options...
