81F Posted August 28, 2014 Share Posted August 28, 2014 Having had my Elite for sometime I think it would be a good idea to update my firmware. does anyone know what cable I need to get to link the elite to my PC? Link to comment Share on other sites More sharing options...
gilbo2 Posted August 28, 2014 Share Posted August 28, 2014 The firmware has been at 1.41 for sometime, which version do you see when starting the Elite? Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 28, 2014 Share Posted August 28, 2014 USB cable for connection 81F. And yes, you should update if not at 1.41. 1.4 made significant capability changes to the Elite and 1.41 fixed the bugs that came in 1.4. Then read the new manual as some things work differently. Make sure you follow the instructions meticulously or it won't work, including starting in upgrade mode by going through that routine with delays. Link to comment Share on other sites More sharing options...
96RAF Posted August 29, 2014 Share Posted August 29, 2014 There are many and various USB cables. The one you need is commonly called a USB printer cable with an A and a B end For the Elite. Link to comment Share on other sites More sharing options...
gilbo2 Posted August 29, 2014 Share Posted August 29, 2014 http://www.ebay.co.uk/itm/1-8M-USB-Cable-V2-0-Type-A-to-Type-B-For-Scanner-Printer-2M-PC-Lead-Male-Epson-/350709180004?pt=UK_Computing_USB_Cables&hash=item51a7e56664 Link to comment Share on other sites More sharing options...
