tony_forward Posted September 15, 2014 Share Posted September 15, 2014 SirPlease find attached log.txt from today. I have had railmaster and elink now for just over one month and I am, to say the least, not impressed.I originally had trouble registering the program and had a nice guy from Hornby sort it for me, but I am now continually having the program crash on me – even since the upgrade to 1.56. Below, please find todays log.txt from which hopefully you will be able to find and solve the problem. I would dearly love to use elink and railmaster at exhibitions but frankly by current experience it is simply not reliable enough. I have an Acer aspire 5332 running windows 7 fully updated, 4gm of memory with 1.8ghz Celeron t3000 processsor Yours Tony Forward (I’m on the forum as tony_forward 15/09/14 14:28:15 RAILMASTER STARTED 1.5615/09/14 14:28:17 Reading Font.dat15/09/14 14:28:17 Reading font.dat chr(33)=! (!)15/09/14 14:28:17 Loaded loco group names15/09/14 14:28:17 Loaded system settings15/09/14 14:28:19 Loading loco detection tags15/09/14 14:28:19 106 loco tag IDs loaded into array15/09/14 14:28:20 After re-loading locos, setting locos panel height=2025015/09/14 14:28:20 Detection IDs in use: ,001,15/09/14 14:28:20 Updated Loco detection IDs array with 1 codes15/09/14 14:28:20 Set position and size of RailMaster form15/09/14 14:28:22 Loaded system specific phrases in English15/09/14 14:28:22 Setting colour scheme to: White15/09/14 14:28:22 Mtl Gradient present=8779815/09/14 14:28:23 Loading loco detection tags15/09/14 14:28:23 106 loco tag IDs loaded into array15/09/14 14:28:25 Loaded phrases for: English15/09/14 14:28:25 Created and deleted test file successfully15/09/14 14:28:25 Windows version: 6.01 (Windows 7) (64-bit)15/09/14 14:28:25 Windows short date format: dd/MM/yyyy15/09/14 14:28:25 Loading INI settings15/09/14 14:28:25 Set tipper speed to 80 speed units15/09/14 14:28:25 Set tipper running time to 86.6 seconds15/09/14 14:28:25 Set turntable speed to 40 speed units15/09/14 14:28:25 Set turntable inter-road run time to 19.3 seconds15/09/14 14:28:25 Set points firing interval to 0.75 seconds15/09/14 14:28:25 Set conveyr speed to 65 speed units15/09/14 14:28:25 Set networking start port to 3015/09/14 14:28:25 Set checking of serial ports on15/09/14 14:28:25 Set allow deactivate15/09/14 14:28:25 Set allowing of default loco speed curves15/09/14 14:28:25 Set TCP polling time to 1 seconds15/09/14 14:28:25 Set confirm deletion dialogs15/09/14 14:28:25 Set detection timeout to 5 seconds15/09/14 14:28:25 Set throttle interval to 5 ms15/09/14 14:28:25 Set Palm interval to 0.07 ms15/09/14 14:28:25 Set ask to set points to 015/09/14 14:28:25 Set plan area to send to handhelds: 1,1,135,13515/09/14 14:28:25 Set program tick sound to 115/09/14 14:28:25 Finished loading INI settings15/09/14 14:28:25 OS Language in use: English (United Kingdom) ENG15/09/14 14:28:25 Loaded language specific labels for RailMaster Window (English)15/09/14 14:28:25 Loaded 16 default speed curves15/09/14 14:28:25 Hardware M/C1: BFEBFBFF0001067ABase Board Serial Number15/09/14 14:28:25 Checking license file15/09/14 14:28:25 Found license file in wpath15/09/14 14:28:25 File date=08/08/200715/09/14 14:28:25 File passes date check15/09/14 14:28:25 Ascertained full version of software15/09/14 14:28:25 File M/C2: BFEBFBFF0001067ABase Board Serial Number15/09/14 14:28:25 Found MSerial ID15/09/14 14:28:25 License passes MSerial check15/09/14 14:28:26 Checking file for updates: Resource.mdb15/09/14 14:28:26 Screen resolution: 96/9615/09/14 14:28:26 Loading loco detection tags15/09/14 14:28:26 106 loco tag IDs loaded into array15/09/14 14:28:27 After re-loading locos, setting locos panel height=2025015/09/14 14:28:27 Detection IDs in use: ,001,15/09/14 14:28:27 Updated Loco detection IDs array with 1 codes15/09/14 14:28:27 Testing for installed languages15/09/14 14:28:27 Main screen left position was: 0 so resetting to zero15/09/14 14:28:27 Main screen top position was: 0 so resetting to zero15/09/14 14:28:27 Checking for latest server settings (HTTP)15/09/14 14:28:30 Downloaded settings (HTTP)15/09/14 14:28:30 Found latest settings and downloaded (http)15/09/14 14:28:30 Read local credentials: rg15/09/14 14:28:30 Settings found to decompress15/09/14 14:28:30 Copied/deleted files successfully15/09/14 14:28:31 Decompressed settings (9...1/e...5/g...r)15/09/14 14:28:31 Checking for program updates (primary server)15/09/14 14:28:31 Checking for updates available in English15/09/14 14:28:31 Checking available version: 1.56 against current: 1.5615/09/14 14:28:31 Downloading updates list15/09/14 14:28:31 Response: (0)15/09/14 14:28:31 First file of updates list: GUIDE_EN.PDF15/09/14 14:28:31 Checking need for: GUIDE_EN.PDF (Size=4649795 Date=09/09/2014)15/09/14 14:28:31 Installed size=4649795 installed date=10/09/201415/09/14 14:28:31 No need to download GUIDE_EN.PDF15/09/14 14:28:31 Checking need for: LICENCE.EN (Size=7759 Date=05/02/2013)15/09/14 14:28:31 Installed size=7760 installed date=26/02/201415/09/14 14:28:31 No need to download LICENCE.EN15/09/14 14:28:31 Checking need for: LANGUAGE.MDB (Size=524288 Date=14/09/2014)15/09/14 14:28:31 Installed size=524288 installed date=15/09/201415/09/14 14:28:31 No need to download LANGUAGE.MDB15/09/14 14:28:32 Checking need for: LOCOS.DAT (Size=195101 Date=08/08/2014)15/09/14 14:28:32 Installed size=195101 installed date=13/09/201415/09/14 14:28:32 No need to download LOCOS.DAT15/09/14 14:28:32 Nothing to do15/09/14 14:28:32 Starting communications with: Hornby eLink on Com315/09/14 14:28:32 Settings: 115200, None, 8, 115/09/14 14:28:32 Current Com port status=False15/09/14 14:28:32 Setting and opening com port: 315/09/14 14:28:32 Set com port successfully15/09/14 14:28:32 Set com port settings successfully: 115200,n,8,115/09/14 14:28:33 Opened Com port successfully15/09/14 14:28:33 Com port status=True15/09/14 14:28:33 Preparing eLink handshake (Port status=True)15/09/14 14:28:33 Initiating handshake with eLink (Port open=True)15/09/14 14:28:38 Received correct response to initial request15/09/14 14:28:40 Handshake completed successfully15/09/14 14:28:41 Requesting response from DCC controller15/09/14 14:28:41 DCC controller response: 99 33 106 1 4115/09/14 14:28:41 Initialised Controller successfully15/09/14 14:28:41 Type: Hornby eLink Version: 1.0615/09/14 14:28:41 Checking eLink firmware: 1.06 against: 1.0615/09/14 14:28:44 Compacted/encrypted resources database15/09/14 14:28:44 Compacted/encrypted language database15/09/14 14:28:44 Showed 13 available Locos on start-up15/09/14 14:28:44 Startup plan set: C:Program Files (x86)RailMasterGarage Layout.pln15/09/14 14:28:44 Loading default plan: C:Program Files (x86)RailMasterGarage Layout.pln15/09/14 14:28:44 Set Plan area: 15500 x 1400015/09/14 14:28:44 First line: *jy†ˆNDFFIF“EFJEE15/09/14 14:28:44 Normalised: Vert:02251~0150015/09/14 14:28:44 Last line: Label:07891~00000~00015~Arial ~008~0~0~0~15/09/14 14:28:44 Loaded default track plan: Garage Layout15/09/14 14:28:44 Loaded all available programs15/09/14 14:28:44 Setting point: 1 to: Left Order: 115/09/14 14:28:45 Setting point: 2 to: Right Order: 215/09/14 14:28:46 Setting point: 5 to: Left Order: 315/09/14 14:28:47 Setting point: 6 to: Right Order: 415/09/14 14:28:48 Setting point: 7 to: Left Order: 515/09/14 14:28:49 Setting point: 4 to: Left Order: 615/09/14 14:28:50 Setting point: 3 to: Left Order: 715/09/14 14:28:51 Setting point: 8 to: Left Order: 815/09/14 14:28:52 Set all default points15/09/14 14:28:52 Showing routes (maxlen=1500)15/09/14 14:28:52 Set all points and signals on sartup15/09/14 14:28:52 Set all default signals15/09/14 14:28:53 Enabled 8 of 8 TCP sockets starting from: 3015/09/14 14:28:53 On startup, setting locos panel height=2025015/09/14 14:28:53 Started with Administrator rights15/09/14 14:28:53 Checking network adapter settings15/09/14 14:28:53 Running IP network check15/09/14 14:28:55 Network connection details for: Atheros AR8132 PCI-E Fast Ethernet Controller (NDIS 6.20)15/09/14 14:28:55 Using DHCP to obtain IP address: YES15/09/14 14:28:55 Auto IP address configuration: YES15/09/14 14:29:08 Showing routes (maxlen=1125)15/09/14 14:29:09 Showing routes (maxlen=1125)15/09/14 14:29:17 Loading loco detection tags15/09/14 14:29:17 106 loco tag IDs loaded into array15/09/14 14:29:17 After re-loading locos, setting locos panel height=3307515/09/14 14:29:18 Detection IDs in use: ,001,15/09/14 14:29:18 Updated Loco detection IDs array with 1 codes15/09/14 14:40:11 Showing routes (maxlen=1125)15/09/14 14:40:12 Showing routes (maxlen=1125)15/09/14 14:40:14 Showing routes (maxlen=1125)15/09/14 14:40:33 Showing routes (maxlen=1125)15/09/14 14:40:34 Showing routes (maxlen=1125)15/09/14 14:40:37 Showing routes (maxlen=1125)15/09/14 14:40:38 Showing routes (maxlen=1125)15/09/14 14:41:27 Showing routes (maxlen=1125)15/09/14 14:41:28 Showing routes (maxlen=1125)15/09/14 14:41:29 Showing routes (maxlen=1125)15/09/14 14:41:30 Showing routes (maxlen=1125)15/09/14 14:41:53 Initiating connection to Licence/Updates server15/09/14 14:41:53 Connecting to remote gateway15/09/14 14:41:53 Setting connection server, username and password15/09/14 14:41:53 Setting remote host15/09/14 14:41:53 Setting server credentials 115/09/14 14:41:53 Setting server credentials 215/09/14 14:41:53 Set up connection to server15/09/14 14:41:53 Entering gateway root for updates check - attempt 115/09/14 14:41:56 Response: The operation completed successfully. (0)15/09/14 14:41:56 Entered gateway root15/09/14 14:41:56 Downloading latest settings (F)15/09/14 14:41:56 Couldn't download latest settings: 200 Type set to I.15/09/14 14:41:56 Entering keys gateway - attempt 115/09/14 14:41:57 Response: The operation completed successfully. (0)15/09/14 14:41:57 Entered resource: S....15/09/14 14:41:57 Connected to server15/09/14 14:41:57 Downloading last connection info to: C:Program Files (x86)RailMaster15/09/14 14:41:58 Response: 200 Type set to I.15/09/14 14:41:58 500 Invalid PORT Command.15/09/14 14:41:58 500 'LPRT 6,16,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2,192,157': command not understood15/09/14 14:41:58 (12003)15/09/14 14:41:58 Updating last connection information15/09/14 14:41:58 Created local file (141 bytes)15/09/14 14:42:00 Response: 200 Type set to I.15/09/14 14:42:00 500 Invalid PORT Command.15/09/14 14:42:00 500 'LPRT 6,16,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2,192,158': command not understood15/09/14 14:42:00 (12003)15/09/14 14:42:00 Couldn't update last connection details: 200 Type set to I.15/09/14 14:42:00 Checking licencing status of software15/09/14 14:42:00 Verifying key: RM2D5CB7BJA7DFG4992B356FA15/09/14 14:42:00 Getting remote licence key (jum) - attempt 115/09/14 14:42:30 Response: 200 Type set to I. (12003)15/09/14 14:42:31 Getting remote licence key (jum) - attempt 215/09/14 14:42:44 Showing routes (maxlen=1125)15/09/14 14:42:45 Showing routes (maxlen=1125)15/09/14 14:42:47 Showing routes (maxlen=1125)15/09/14 14:42:48 Showing routes (maxlen=1125)15/09/14 14:43:01 Response: 200 Type set to I. (12003)15/09/14 14:43:02 Getting remote licence key (jum) - attempt 315/09/14 14:43:28 Showing routes (maxlen=1125)15/09/14 14:43:29 Showing routes (maxlen=1125)15/09/14 14:43:32 Response: 200 Type set to I. (12003)15/09/14 14:43:33 Getting remote licence key (nor) - attempt 115/09/14 14:44:03 Response: 200 Type set to I. (12003)15/09/14 14:44:04 Getting remote licence key (nor) - attempt 2 At this point the only thing I can do is to use task manager to close the program!I tried to send this from the help part of the program but it crashed again! Link to comment Share on other sites More sharing options...
tony_forward Posted September 15, 2014 Author Share Posted September 15, 2014 Oops - not sure how it got there twice.... Sorry Link to comment Share on other sites More sharing options...
walkingthedog Posted September 15, 2014 Share Posted September 15, 2014 Have you sent this to Railmaster support, or is that what you meant in the last paragraph? Link to comment Share on other sites More sharing options...
tony_forward Posted September 15, 2014 Author Share Posted September 15, 2014 I tried but the program crashed again So I have no idea if they received it or not!After 2 restarts it seems to be running ok at the moment, but surely it shouldnt crash so often! Link to comment Share on other sites More sharing options...
tony_forward Posted September 15, 2014 Author Share Posted September 15, 2014 I've just tried to send it again so And it says:-Could not send your request for help at this timePlease try again shortly200 type set to 1. 12003 So even thats not working for me :( Link to comment Share on other sites More sharing options...
PJ_model_trains Posted September 15, 2014 Share Posted September 15, 2014 Hi TonyJust hang on a while they periodically watch this section of the forum.They will probably want access to your computer for these tyes of conflict. It is very easy and safe and they are very helpful. PJ Link to comment Share on other sites More sharing options...
tony_forward Posted September 15, 2014 Author Share Posted September 15, 2014 Thanks PJ, I was hoping for something like that! Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted September 15, 2014 Share Posted September 15, 2014 You should ask Hornby to delete this post as it includes your product key.Please note, we cannot take reponsibility for anybody using your key, which you have published, where you cannot then use your software in the future.RailMaster does not crash, as a product. If it is crashing on your system then something on your system is causing this. By "crashing" we infer that the program stops dead with a Windows-generated error message ro jsut terminates.The fact that you are unable to send a Help Request (we have received nothing from you) indicates that RailMaster is being blocked on your system.You need to read the Internet Security guide first. You can also temporarily disable your antivirus software and try to send a Help Request. If this goes through then you know that RailMaster has not been added correctly to your antivirus and firewall software.We received a comment from one user recently. who was fed up with McAfee and that uninstalling McAffee (if that is what you have) resolves all issues with RailMaster in terms of communications and "crashing".When we researched AV products to produce the helpful Internet Security guide, we found that McAfee was by far and away the worst to deal with. Unfortunately, it is also one of the most widely used as large companies give it away with the computers and services. Link to comment Share on other sites More sharing options...
tony_forward Posted September 15, 2014 Author Share Posted September 15, 2014 Thanks for the reply. I have AVG on my laptop, not mcaffee. i get no windows error or any other error, the program simply stops working! I asked once on here whether railmaster needs internet access to work properly and i am wondering if the fact that the layout is in the garage with little or no internet access is the problem. Can you tell from the log file that I sent what is stopping the program? If indeed the problem is lack of internet then my intention pf using railmaster/elink on an exhibition layout is a non-starter as most venues do not have internet access for visitors. RegardsTony Ps i have asked hornby to edit or delete the post Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted September 15, 2014 Share Posted September 15, 2014 Tony - you are confusing needing Internet access to send a Help Request or activate the product, with needing Internet access to run the program generally.Clearly any activity that requires communications with us (activation, Help Requests) needs some form of communication to get in touch with us .... Internet.Running your trains, switching points, setting signals etc. require no form of communication with the outside world. Link to comment Share on other sites More sharing options...
tony_forward Posted September 15, 2014 Author Share Posted September 15, 2014 I have replied on the other post.. Thanks. Link to comment Share on other sites More sharing options...
mcrook62 Posted September 15, 2014 Share Posted September 15, 2014 Hi TonyJust a quick question have you read the railmaster 1.56 manual because when you are at a exhibition to run your trains and points and signals etc needs no input from the internet you have your computer setup and your elite switch on and away you go.mcrook62 Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 16, 2014 Share Posted September 16, 2014 Not sure what your question is mc but you don't need internet when running RM, only when updating, activating and emailing. Link to comment Share on other sites More sharing options...
