tony_forward Posted September 15, 2014 Share Posted September 15, 2014 SirPlease find attached log.txt from today. I have had railmaster and elink now for just over one month and I am, to say the least, not impressed.I originally had trouble registering the program and had a nice guy from Hornby sort it for me, but I am now continually having the program crash on me – even since the upgrade to 1.56. Below, please find todays log.txt from which hopefully you will be able to find and solve the problem. I would dearly love to use elink and railmaster at exhibitions but frankly by current experience it is simply not reliable enough. I have an Acer aspire 5332 running windows 7 fully updated, 4gm of memory with 1.8ghz Celeron t3000 processsor Yours Tony Forward (I’m on the forum as tony_forward 15/09/14 14:28:15 RAILMASTER STARTED 1.5615/09/14 14:28:17 Reading Font.dat15/09/14 14:28:17 Reading font.dat chr(33)=! (!)15/09/14 14:28:17 Loaded loco group names15/09/14 14:28:17 Loaded system settings15/09/14 14:28:19 Loading loco detection tags15/09/14 14:28:19 106 loco tag IDs loaded into array15/09/14 14:28:20 After re-loading locos, setting locos panel height=2025015/09/14 14:28:20 Detection IDs in use: ,001,15/09/14 14:28:20 Updated Loco detection IDs array with 1 codes15/09/14 14:28:20 Set position and size of RailMaster form15/09/14 14:28:22 Loaded system specific phrases in English15/09/14 14:28:22 Setting colour scheme to: White15/09/14 14:28:22 Mtl Gradient present=8779815/09/14 14:28:23 Loading loco detection tags15/09/14 14:28:23 106 loco tag IDs loaded into array15/09/14 14:28:25 Loaded phrases for: English15/09/14 14:28:25 Created and deleted test file successfully15/09/14 14:28:25 Windows version: 6.01 (Windows 7) (64-bit)15/09/14 14:28:25 Windows short date format: dd/MM/yyyy15/09/14 14:28:25 Loading INI settings15/09/14 14:28:25 Set tipper speed to 80 speed units15/09/14 14:28:25 Set tipper running time to 86.6 seconds15/09/14 14:28:25 Set turntable speed to 40 speed units15/09/14 14:28:25 Set turntable inter-road run time to 19.3 seconds15/09/14 14:28:25 Set points firing interval to 0.75 seconds15/09/14 14:28:25 Set conveyr speed to 65 speed units15/09/14 14:28:25 Set networking start port to 3015/09/14 14:28:25 Set checking of serial ports on15/09/14 14:28:25 Set allow deactivate15/09/14 14:28:25 Set allowing of default loco speed curves15/09/14 14:28:25 Set TCP polling time to 1 seconds15/09/14 14:28:25 Set confirm deletion dialogs15/09/14 14:28:25 Set detection timeout to 5 seconds15/09/14 14:28:25 Set throttle interval to 5 ms15/09/14 14:28:25 Set Palm interval to 0.07 ms15/09/14 14:28:25 Set ask to set points to 015/09/14 14:28:25 Set plan area to send to handhelds: 1,1,135,13515/09/14 14:28:25 Set program tick sound to 115/09/14 14:28:25 Finished loading INI settings15/09/14 14:28:25 OS Language in use: English (United Kingdom) ENG15/09/14 14:28:25 Loaded language specific labels for RailMaster Window (English)15/09/14 14:28:25 Loaded 16 default speed curves15/09/14 14:28:25 Hardware M/C1: BFEBFBFF0001067ABase Board Serial Number15/09/14 14:28:25 Checking license file15/09/14 14:28:25 Found license file in wpath15/09/14 14:28:25 File date=08/08/200715/09/14 14:28:25 File passes date check15/09/14 14:28:25 Ascertained full version of software15/09/14 14:28:25 File M/C2: BFEBFBFF0001067ABase Board Serial Number15/09/14 14:28:25 Found MSerial ID15/09/14 14:28:25 License passes MSerial check15/09/14 14:28:26 Checking file for updates: Resource.mdb15/09/14 14:28:26 Screen resolution: 96/9615/09/14 14:28:26 Loading loco detection tags15/09/14 14:28:26 106 loco tag IDs loaded into array15/09/14 14:28:27 After re-loading locos, setting locos panel height=2025015/09/14 14:28:27 Detection IDs in use: ,001,15/09/14 14:28:27 Updated Loco detection IDs array with 1 codes15/09/14 14:28:27 Testing for installed languages15/09/14 14:28:27 Main screen left position was: 0 so resetting to zero15/09/14 14:28:27 Main screen top position was: 0 so resetting to zero15/09/14 14:28:27 Checking for latest server settings (HTTP)15/09/14 14:28:30 Downloaded settings (HTTP)15/09/14 14:28:30 Found latest settings and downloaded (http)15/09/14 14:28:30 Read local credentials: rg15/09/14 14:28:30 Settings found to decompress15/09/14 14:28:30 Copied/deleted files successfully15/09/14 14:28:31 Decompressed settings (9...1/e...5/g...r)15/09/14 14:28:31 Checking for program updates (primary server)15/09/14 14:28:31 Checking for updates available in English15/09/14 14:28:31 Checking available version: 1.56 against current: 1.5615/09/14 14:28:31 Downloading updates list15/09/14 14:28:31 Response: (0)15/09/14 14:28:31 First file of updates list: GUIDE_EN.PDF15/09/14 14:28:31 Checking need for: GUIDE_EN.PDF (Size=4649795 Date=09/09/2014)15/09/14 14:28:31 Installed size=4649795 installed date=10/09/201415/09/14 14:28:31 No need to download GUIDE_EN.PDF15/09/14 14:28:31 Checking need for: LICENCE.EN (Size=7759 Date=05/02/2013)15/09/14 14:28:31 Installed size=7760 installed date=26/02/201415/09/14 14:28:31 No need to download LICENCE.EN15/09/14 14:28:31 Checking need for: LANGUAGE.MDB (Size=524288 Date=14/09/2014)15/09/14 14:28:31 Installed size=524288 installed date=15/09/201415/09/14 14:28:31 No need to download LANGUAGE.MDB15/09/14 14:28:32 Checking need for: LOCOS.DAT (Size=195101 Date=08/08/2014)15/09/14 14:28:32 Installed size=195101 installed date=13/09/201415/09/14 14:28:32 No need to download LOCOS.DAT15/09/14 14:28:32 Nothing to do15/09/14 14:28:32 Starting communications with: Hornby eLink on Com315/09/14 14:28:32 Settings: 115200, None, 8, 115/09/14 14:28:32 Current Com port status=False15/09/14 14:28:32 Setting and opening com port: 315/09/14 14:28:32 Set com port successfully15/09/14 14:28:32 Set com port settings successfully: 115200,n,8,115/09/14 14:28:33 Opened Com port successfully15/09/14 14:28:33 Com port status=True15/09/14 14:28:33 Preparing eLink handshake (Port status=True)15/09/14 14:28:33 Initiating handshake with eLink (Port open=True)15/09/14 14:28:38 Received correct response to initial request15/09/14 14:28:40 Handshake completed successfully15/09/14 14:28:41 Requesting response from DCC controller15/09/14 14:28:41 DCC controller response: 99 33 106 1 4115/09/14 14:28:41 Initialised Controller successfully15/09/14 14:28:41 Type: Hornby eLink Version: 1.0615/09/14 14:28:41 Checking eLink firmware: 1.06 against: 1.0615/09/14 14:28:44 Compacted/encrypted resources database15/09/14 14:28:44 Compacted/encrypted language database15/09/14 14:28:44 Showed 13 available Locos on start-up15/09/14 14:28:44 Startup plan set: C:Program Files (x86)RailMasterGarage Layout.pln15/09/14 14:28:44 Loading default plan: C:Program Files (x86)RailMasterGarage Layout.pln15/09/14 14:28:44 Set Plan area: 15500 x 1400015/09/14 14:28:44 First line: *jy†ˆNDFFIF“EFJEE15/09/14 14:28:44 Normalised: Vert:02251~0150015/09/14 14:28:44 Last line: Label:07891~00000~00015~Arial ~008~0~0~0~15/09/14 14:28:44 Loaded default track plan: Garage Layout15/09/14 14:28:44 Loaded all available programs15/09/14 14:28:44 Setting point: 1 to: Left Order: 115/09/14 14:28:45 Setting point: 2 to: Right Order: 215/09/14 14:28:46 Setting point: 5 to: Left Order: 315/09/14 14:28:47 Setting point: 6 to: Right Order: 415/09/14 14:28:48 Setting point: 7 to: Left Order: 515/09/14 14:28:49 Setting point: 4 to: Left Order: 615/09/14 14:28:50 Setting point: 3 to: Left Order: 715/09/14 14:28:51 Setting point: 8 to: Left Order: 815/09/14 14:28:52 Set all default points15/09/14 14:28:52 Showing routes (maxlen=1500)15/09/14 14:28:52 Set all points and signals on sartup15/09/14 14:28:52 Set all default signals15/09/14 14:28:53 Enabled 8 of 8 TCP sockets starting from: 3015/09/14 14:28:53 On startup, setting locos panel height=2025015/09/14 14:28:53 Started with Administrator rights15/09/14 14:28:53 Checking network adapter settings15/09/14 14:28:53 Running IP network check15/09/14 14:28:55 Network connection details for: Atheros AR8132 PCI-E Fast Ethernet Controller (NDIS 6.20)15/09/14 14:28:55 Using DHCP to obtain IP address: YES15/09/14 14:28:55 Auto IP address configuration: YES15/09/14 14:29:08 Showing routes (maxlen=1125)15/09/14 14:29:09 Showing routes (maxlen=1125)15/09/14 14:29:17 Loading loco detection tags15/09/14 14:29:17 106 loco tag IDs loaded into array15/09/14 14:29:17 After re-loading locos, setting locos panel height=3307515/09/14 14:29:18 Detection IDs in use: ,001,15/09/14 14:29:18 Updated Loco detection IDs array with 1 codes15/09/14 14:40:11 Showing routes (maxlen=1125)15/09/14 14:40:12 Showing routes (maxlen=1125)15/09/14 14:40:14 Showing routes (maxlen=1125)15/09/14 14:40:33 Showing routes (maxlen=1125)15/09/14 14:40:34 Showing routes (maxlen=1125)15/09/14 14:40:37 Showing routes (maxlen=1125)15/09/14 14:40:38 Showing routes (maxlen=1125)15/09/14 14:41:27 Showing routes (maxlen=1125)15/09/14 14:41:28 Showing routes (maxlen=1125)15/09/14 14:41:29 Showing routes (maxlen=1125)15/09/14 14:41:30 Showing routes (maxlen=1125)15/09/14 14:41:53 Initiating connection to Licence/Updates server15/09/14 14:41:53 Connecting to remote gateway15/09/14 14:41:53 Setting connection server, username and password15/09/14 14:41:53 Setting remote host15/09/14 14:41:53 Setting server credentials 115/09/14 14:41:53 Setting server credentials 215/09/14 14:41:53 Set up connection to server15/09/14 14:41:53 Entering gateway root for updates check - attempt 115/09/14 14:41:56 Response: The operation completed successfully. (0)15/09/14 14:41:56 Entered gateway root15/09/14 14:41:56 Downloading latest settings (F)15/09/14 14:41:56 Couldn't download latest settings: 200 Type set to I.15/09/14 14:41:56 Entering keys gateway - attempt 115/09/14 14:41:57 Response: The operation completed successfully. (0)15/09/14 14:41:57 Entered resource: S....15/09/14 14:41:57 Connected to server15/09/14 14:41:57 Downloading last connection info to: C:Program Files (x86)RailMaster15/09/14 14:41:58 Response: 200 Type set to I.15/09/14 14:41:58 500 Invalid PORT Command.15/09/14 14:41:58 500 'LPRT 6,16,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2,192,157': command not understood15/09/14 14:41:58 (12003)15/09/14 14:41:58 Updating last connection information15/09/14 14:41:58 Created local file (141 bytes)15/09/14 14:42:00 Response: 200 Type set to I.15/09/14 14:42:00 500 Invalid PORT Command.15/09/14 14:42:00 500 'LPRT 6,16,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,2,192,158': command not understood15/09/14 14:42:00 (12003)15/09/14 14:42:00 Couldn't update last connection details: 200 Type set to I.15/09/14 14:42:00 Checking licencing status of software15/09/14 14:42:00 Verifying key: RM2D5CB7BJA7DFG4992B356FA15/09/14 14:42:00 Getting remote licence key (jum) - attempt 115/09/14 14:42:30 Response: 200 Type set to I. (12003)15/09/14 14:42:31 Getting remote licence key (jum) - attempt 215/09/14 14:42:44 Showing routes (maxlen=1125)15/09/14 14:42:45 Showing routes (maxlen=1125)15/09/14 14:42:47 Showing routes (maxlen=1125)15/09/14 14:42:48 Showing routes (maxlen=1125)15/09/14 14:43:01 Response: 200 Type set to I. (12003)15/09/14 14:43:02 Getting remote licence key (jum) - attempt 315/09/14 14:43:28 Showing routes (maxlen=1125)15/09/14 14:43:29 Showing routes (maxlen=1125)15/09/14 14:43:32 Response: 200 Type set to I. (12003)15/09/14 14:43:33 Getting remote licence key (nor) - attempt 115/09/14 14:44:03 Response: 200 Type set to I. (12003)15/09/14 14:44:04 Getting remote licence key (nor) - attempt 2 At this point the only thing I can do is to use task manager to close the program!I tried to send this from the help part of the program but it crashed again! Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted September 15, 2014 Share Posted September 15, 2014 You should ask Hornby to delete this post as it includes your product key.Please note, we cannot take reponsibility for anybody using your key, which you have published, where you cannot then use your software in the future. Link to comment Share on other sites More sharing options...
tony_forward Posted September 15, 2014 Author Share Posted September 15, 2014 I cant send anything to hornby, rail,aster says so! Link to comment Share on other sites More sharing options...
Yelrow Posted September 15, 2014 Share Posted September 15, 2014 no they dont, you just email them through Railmaster, asking for help. They then arrange a time, take over your computer and sort it. All very civilsed. All the info you are trying to send them, they already have. john Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted September 15, 2014 Share Posted September 15, 2014 Tony_Forward ... please read the posting carefully.You have published your RailMaster product key for the world to see.If somebody else uses that key in the future and you can no longer gain access to your licensed copy of RailMaster there is nothing we can do about it.You should use the "Report" button to ask the Hornby web forum team to delete your original post, and the duplicate one.That should be your priority right now, then you can read our replies, read the documentation, follow the instructions and send a Help Request from within the software. Link to comment Share on other sites More sharing options...
tony_forward Posted September 15, 2014 Author Share Posted September 15, 2014 I have used the report button on both posts, so hopefully all will be well. Ok , situation is as follows.my laptop had windows 8 on it and mcaffee. I added the railmaster software to the exceptions and still couldnt activate it. I formatted the hard drive and went back to windows 7 with AVG as the anti virus (mcaffee being overpriced) railmaster is added to the firewall and the antivirus as an exception and still unable to activate it. A guy from ?hornby? Or railmaster logged in to my machine and activated the software. So far, so good. Then I take the laptop to the garage and run the Layout. The railmaster program 'freezes' quite often, which is, as you can imagine, very frustrating. Looking at the log file that I have published (as there seemed no other way to show you) it appears to me that it may be a problem accessing the internet - which does not surprise me as it doesnt work well in the garage! If this is the case please tell me and I can make alternative arrangements for controlling the layout (going back to the select which works well) This afternoon I had the problem again and copied the log file, the layout then ran well for over an hour so the current log file has no problems on it other than being unable to send the help file. Help please!! Link to comment Share on other sites More sharing options...
tony_forward Posted September 15, 2014 Author Share Posted September 15, 2014 The bit that I'm looking at on the log file is:)15/09/14 14:42:00 Getting remote licence key (jum) - attempt 115/09/14 14:42:30 Response: 200 Type set to I. (12003)15/09/14 14:42:31 Getting remote licence key (jum) - attempt 215/09/14 14:42:44 Showing routes (maxlen=1125)15/09/14 14:42:45 Showing routes (maxlen=1125)15/09/14 14:42:47 Showing routes (maxlen=1125)15/09/14 14:42:48 Showing routes (maxlen=1125)15/09/14 14:43:01 Response: 200 Type set to I. (12003)15/09/14 14:43:02 Getting remote licence key (jum) - attempt 315/09/14 14:43:28 Showing routes (maxlen=1125)15/09/14 14:43:29 Showing routes (maxlen=1125)15/09/14 14:43:32 Response: 200 Type set to I. (12003)15/09/14 14:43:33 Getting remote licence key (nor) - attempt 115/09/14 14:44:03 Response: 200 Type set to I. (12003)15/09/14 14:44:04 Getting remote licence key (nor) - attempt 2 And then it freezes? Link to comment Share on other sites More sharing options...
Yelrow Posted September 15, 2014 Share Posted September 15, 2014 why not boost the wifi, mine goes for 80 metres. Alternatively, take laptop and elink into house and connect and re connect, and see if still a problem. You never have to publish the log file, as hornby have a copy, every time you log on, they can see . I use norton anti virus, that works well, john. Going back to select, would be a waste, john Link to comment Share on other sites More sharing options...
Yelrow Posted September 15, 2014 Share Posted September 15, 2014 You dont need internet at all to run trains, elink, or railmaster. I have no internet in my loft. When i want to contact support, i bring laptop in range john Link to comment Share on other sites More sharing options...
tony_forward Posted September 15, 2014 Author Share Posted September 15, 2014 Hi John.Agree that going back to the select would be a waste, but at the moment although I love the way the elink works and want to persevere I am getting more than a little frustrated with the continual freezing of the railmaster program! I really wouldn't feel comfortable at the moment taking a layout to an exhibition with railmaster as the controller of choice, i simply have not found it reliable enough. Link to comment Share on other sites More sharing options...
Yelrow Posted September 15, 2014 Share Posted September 15, 2014 elink is far more versatile for exhibitions than a select. Have you tried to control 2 trains at once with a select. Running 5 or six at once with elink, when 100%, is very good, far easier, to maintain. I have both, when kids come, let them use select. What about points and signals with a select, the mind boggles. I presume somebody has asked you before, but you DO have a 4 amp transformer, with your elink, dont you.. Your elink is not the problem, its only a bridge between the track and railmaster. Its your anti virus, or laptop, usb lead, windows 8, one of those or a mixture of both. I have not known hornby support, to be beaten yet. There is a school of thought that xp is very stable, if your going to exhibitions, you could pick up a laptop with xp, for a song on ebay, as a specialist use machine. john Link to comment Share on other sites More sharing options...
tony_forward Posted September 15, 2014 Author Share Posted September 15, 2014 john, you're right, elink and railmaster would be ideal, i was at an exhibition last week on an N gauge dcc layout with an nce powercab, no points, pretty much one loco at a time and my elink is much more user friendly. Maybe an xp machine would be the answer. If the internet is not a necessity other than activation or help, then if someone tells me why the program freezes so often then I could do something about it :) Link to comment Share on other sites More sharing options...
tony_forward Posted September 15, 2014 Author Share Posted September 15, 2014 and yes, windows 7 AVG as the antivirus with railmaster as an exception and a 4amp transformer... Elink is fine, its railmaster I have the problem with! Link to comment Share on other sites More sharing options...
SHEDINGTON Posted September 15, 2014 Share Posted September 15, 2014 Hi Tony don't know if this will be helpful but maybe a point to note I kept my layout in the shed which was great but when I introduced DCC I stated to get problems with laptops PC's etc not functioning well crashing for no reason, eratic start up. I put it down mainly to damp cold conditions in the shed affecting both electronics in the pc/chips in the locos ,and weak wifi Since moving indoors (insulated loft in the extension) problems resolved ......I know we are having rather a nice autumn at the mo but garages can be cold and damp .......The only other things is as Support said there must be a conflict on you pc, pretty sure you don't need internet to operate Railmaster tho Dodge Link to comment Share on other sites More sharing options...
Yelrow Posted September 15, 2014 Share Posted September 15, 2014 No, tony, its not Railmaster either, its the windows/ laptop.. Hornby trialed this for yonks before releasing it I live in france, and have had awful trouble with connections, due i belive to location. Hornby have twice looked at my french machine, with french windows , and manfully made it run.. I think it you put it in a dedicated XP laptop, you would be sorted. Railmaster has been about a long time, and worked a treat with early windows. . john Link to comment Share on other sites More sharing options...
tony_forward Posted September 15, 2014 Author Share Posted September 15, 2014 looks like a new "old" laptop is called for :) Dodge - laptop lives indoors till i need it :) Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 16, 2014 Share Posted September 16, 2014 It will work on W7, email RM Support. Best to do it from RM but if crashing, you can get them direct at support@rail-master.com Link to comment Share on other sites More sharing options...
tony_forward Posted September 16, 2014 Author Share Posted September 16, 2014 thanks Fish! That's what I needed! Link to comment Share on other sites More sharing options...
Jailor Posted September 16, 2014 Share Posted September 16, 2014 If it gives you more choice, I pinched my wife's old laptop running Vista and have had no issues loading or running RM, good luck.Ron. Link to comment Share on other sites More sharing options...
tony_forward Posted September 16, 2014 Author Share Posted September 16, 2014 thanks Admin... I'm obliged. tony Link to comment Share on other sites More sharing options...
TOMMY68 Posted September 17, 2014 Share Posted September 17, 2014 Hi Tony I was running RM/elink on a windows 8 laptop - bought for the purpose. Everything was running brilliantly on v1.55. However, did the update and it all went wrong. Sounds like exactly the same issues you were having. HRMS were great, in that they took my machine a couple of times, sorted it, following which things operated for about 10 minutes followed by everything freezing - locking up whatever it's called. Couldn't even get the task manager to close the programme.There was McAfee AV on the machine, but did a factory reset and removed as much as I could - still not happy, so basically I have given up completely and decided that I can do without the hassle.I'm really disappointed with the whole thing really, but I guess you learn by your mistakes. Can't fault the help and support provided by HRMS and this forum, this has all been tremendous and I really do appreciate the help and advice I have been given.However, I just want to operate my layout in as striaght forward manner possible, which I was able to do before this update, so I have decided that all this technology isn't for me and it's back to basics in terms of my DCC control. Link to comment Share on other sites More sharing options...
TOMMY68 Posted September 18, 2014 Share Posted September 18, 2014 Hi Admin thanks for taking the time to read and reply. I really can't praise the level of support enough, they genuinely are brilliant. I am a regular user of computers both professionally and personally, all of which do what I want them to do when I turn them on. What I'm not brilliant at, nor have any intention in being, is dealing with hardware or software issues... I just like things to work as they should, which isn't really an unreasonable assumption. I had reviewed, reviewed and reviewed before deciding to go with the elink and railmaster set up - despite some of the more negative reviews, I really thought it was worth a go, Hornby being my introduction to DCC with the Select. I even bought a new laptop for the purpose of running the package, as I prefer to use Apple products as opposed to Windows machines. But, despite the best efforts of everyone on this forum and the Support team, I regret to say that I am not prepared to suffer the uncertainty of it all. I know from this forum many people have had issues when setting up for the first time, which I was really surprised and happy that I didn't, as installing v1.55 everything worked brilliantly - first time everytime. Unfortunately, following the update, it's all gone a bit pear shaped.So the new laptop and RM/e-link will gather dust under my layout, whilst my Select does what it needs to to operate things. I know that I am not the most patient of individuals and enjoy a good rant at my work computer (Windows again), assuming the louder you shout it will eventually do as you have asked it, so perhaps I will be in the minority in taking the decision I have and may even regret it, time will tell.Who knows, in the future I may decide to dust off the elink and give another go, but for now, whilst an Unhappy Bunny in terms of my choice of a new controller, I can still enjoy the basics of my hobby thanks to my Hornby models and Select Controller, which is all I've ever wanted to do really..Very best wishes and a heartfelt thanks for this forum - it really is a brilliant source of help and support - hopefully I'm still allowed to be part of it :-). Link to comment Share on other sites More sharing options...
tony_forward Posted September 21, 2014 Author Share Posted September 21, 2014 My thanks to Admin for cleaning up my Thread. I have read the answers on here and on other threads about Internet access and anti-virus programs and would like to make the following observation.My laptop has AVG free on it, not Mcaffee and is using the windows firewall. RM is an exception on both.I am 99 percent certain that there is no trace of Mcaffee but will check again when I return from holiday, perhaps RM support will log on to my pc again for me and check that everything is as it should be when I return. The thread certainly seems to have stirred up some responses and I'm sure that eventually we will all get sorted and be happy bunnies Link to comment Share on other sites More sharing options...
