rpjallan Posted September 18, 2014 Share Posted September 18, 2014 As the title says, my Forward - Reverse is not working on my HandHeld device after 1.56 update. Everthing else works. In the HH log file it is sending the command and RailMaster is receiving it because it beeps and the little panel flashes but the direction of the loco doesn't change.Any ideas or suggestions? Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 18, 2014 Share Posted September 18, 2014 Is your HH updated to the latest version, v1.2 for iOS? Link to comment Share on other sites More sharing options...
rpjallan Posted September 18, 2014 Author Share Posted September 18, 2014 Yes, updated to v1.2... Link to comment Share on other sites More sharing options...
OssieB Posted September 18, 2014 Share Posted September 18, 2014 Glad to know that I am not the only one experiencing this problem. I came across it when I updated to 1.56 for RM and 1.20 for handheld iPad, last week. As there were no forum topics about the problem, I contacted HRMS via the Help route. I very quickly had a reply from HRMS advising they would look into it and provide a solution. As yet I have not had any further update, but I will post any reply when received.I did find that the non operation of the Fwd/Rev button on the handheld only occurs if you have tick the "Reverse direction controls" in System Settings in RM. If it is unchecked, then everything appears to work correctly. However, I wish to stick with the normal UK convention of forward being to the left if I can. I also have noticed that on start up on RM that the direction of all locos are shown as "Reverse", which I do think was the case with previous version.(I have not used RM for a couple of months, so I may be wrong).Generally I have had no problems with RM nor the updates and are very please with the system and eLink. I run RM on a PC with XP.Barry Link to comment Share on other sites More sharing options...
andy_jackson Posted September 19, 2014 Share Posted September 19, 2014 Same here. Must be an issue that is being worked on?the help received so far from railmaster team has been very good, so I am sure this will be resolved soon.Andy Link to comment Share on other sites More sharing options...
gilbo2 Posted September 19, 2014 Share Posted September 19, 2014 Try taking a fresh download of http://www.powerpos.com/rail-master/rm_setup.exe and running. You made find its been fixed? Link to comment Share on other sites More sharing options...
rpjallan Posted September 20, 2014 Author Share Posted September 20, 2014 I have checked this again just now with the latest available download and it is not working. I have sent a help request through RailMaster. Anyone else having this problem should do the same, I guess, so they know it's not just a one off. Link to comment Share on other sites More sharing options...
rpjallan Posted September 20, 2014 Author Share Posted September 20, 2014 I have just received this reply:We too have discovered that and a fix is being made which should update to your device shortly. Link to comment Share on other sites More sharing options...
OssieB Posted September 22, 2014 Share Posted September 22, 2014 I have just downloaded the lastest update for 1.56 and can report that this problem has now been resolved.Well done HRMS and thank you.Barry. Link to comment Share on other sites More sharing options...
andy_jackson Posted September 25, 2014 Share Posted September 25, 2014 Programme automatically updated and bug fixed. Thanks and well done echoed.Andy Link to comment Share on other sites More sharing options...
rpjallan Posted September 27, 2014 Author Share Posted September 27, 2014 Yes, all fixed now. However, the update to the Hand Held app was a bit of a struggle... Link to comment Share on other sites More sharing options...
