Yelrow Posted September 19, 2014 Share Posted September 19, 2014 hi, i have the Lindisfarne diesel that came with Majestic set 47789, which has an aversion to tight curves and poits, and a new A4 mallard DCC ready. Can i simply put the diesel decoder in the mallard, john Link to comment Share on other sites More sharing options...
poliss Posted September 19, 2014 Share Posted September 19, 2014 Yep, provided the sockets are the same. i.e. Both 8 or 21 pin. Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 19, 2014 Share Posted September 19, 2014 And the decoder will of course retain whatever address you gave it in the diesel. Link to comment Share on other sites More sharing options...
Augustus Caesar Posted September 20, 2014 Share Posted September 20, 2014 Don't forget to re plug the Lindisfarne John with its blanking plug if not placing a new decoder in her... :-) Obvious I know but.... Link to comment Share on other sites More sharing options...
Jailor Posted September 20, 2014 Share Posted September 20, 2014 Hi John I have same set and had loads of problems with Peppercorn and Lindisfarne, although a cheaper way of getting started it seems having read other customers stories that the trains are probmatic in this set.I had problems with the Lindisfarne when running it as it seemed to be dragging some of the drive wheels, Hornby reset the chip and this cured the problem so don't know if this could help you. Ron. Link to comment Share on other sites More sharing options...
Yelrow Posted September 20, 2014 Author Share Posted September 20, 2014 Jailor, hi, Peppercorn is with hornby, as wheel screw came out, but its fair to say, it ran well before. I think the diesel may be my fault, as i am asking it to go round some tight curves. I have a new Mallard waiting for a chip, running on DC, so thought i would switch them over. Knew nothing about replacing the blanking plug, thank you augustus, will it just be inside the body.Do i have to have it to run on DC. Dont know how many pins yet. just assumed they would be the same, john Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 20, 2014 Share Posted September 20, 2014 John, your DCC ready Mallard will have a blanking plug in the socket where the decoder plugs in. This allows it to run DC and you have to remove it to install the decoder. When you remove it and put in the decoder from the diesel, you should then put the blsnking plug into the diesel socket so it will run DC. If the Mallard is Hornby, the DCC socket will be 8-pin just like in the Majestic set locos. Link to comment Share on other sites More sharing options...
