shippingboy Posted October 25, 2014 Share Posted October 25, 2014 I do hope this is not another serious glitch - having got Railmaster working after a long time and a lot of help from Hornby support I have just started it up after a few weeks absence and low and behold I get the above - I have done all the 'normal' things ie switch off /reboot etc etc but the same thing happens - any ideas anyone thanks Mike Link to comment Share on other sites More sharing options...
RB51 Posted October 25, 2014 Share Posted October 25, 2014 I am no expert - but that sounds like a Widows error rather than a RM one. I would wait for HRMS to pick this up and confirm or otherwise what is going on here. Maybe Admin could move this to the RM sub-forum where it should be seen and responded to a bit quicker than this one. R- Link to comment Share on other sites More sharing options...
poliss Posted October 25, 2014 Share Posted October 25, 2014 Is there an error number, such as 429? Have you tried Googling the exact error message? Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 26, 2014 Share Posted October 26, 2014 Ask RM Suport again. agree it is a Windows error though, not RM as such. Link to comment Share on other sites More sharing options...
Augustus Caesar Posted October 27, 2014 Share Posted October 27, 2014 This could be a program error or Windows error. Usually with this message a database can be at fault. Maybe the RM database is causing an issue or is not being read properly. Another possible cause is a Windows update not installing properly but there are other possibilities... You could try a system restore to go back to the time the last one was created... usually after an installl or update etc. The clue about the database possibility is in the can't create object as the program is trying to write something. As Fishy says RM support should be able to advise what this object is supposed to be and why the error occurs. Link to comment Share on other sites More sharing options...
shippingboy Posted October 27, 2014 Author Share Posted October 27, 2014 dear all thanks for your advice I will contact RM support - I cant do it through the program as there are no gRaptors so I will contact the guys at support many thanks brgds mike Link to comment Share on other sites More sharing options...
shippingboy Posted October 27, 2014 Author Share Posted October 27, 2014 dear all thanks for your advice I will contact RM support - I cant do it through the program as there are no graphics so I will contact the guys at support many thanks brgds mike Link to comment Share on other sites More sharing options...
Fishmanoz Posted October 27, 2014 Share Posted October 27, 2014 You should contact RM Support either at support@rail-master.com or just replying to the email they sent to you. No point ringing or emailing HCC.Admin edit: Support email address amended ('_' changed to '-') Link to comment Share on other sites More sharing options...
