rattlerMark Posted November 17, 2014 Share Posted November 17, 2014 Can someone please help – I am using Rail-Master Version 1.56 and trying to add sound Wav files to my Rail Program (announcements held in the Rail Master sound folder) – this used to be easy under version 1.20 as it displayed a search box but that no longer appears to be happening. I’ve added a new line using the+ key on the Rail Program page , and then selected from the “Resources” column the program command icon then in next column with the heading “Resource Name” entered “program command” (the only option available), then from the “Instruction” Column selected “Play Sound” at this point there appears no way of adding a Wav file from the Rail Master Sound file folder and therefore I have tried cutting and pasting a Wav file onto the Rail Program page but as soon as I move out of the "Instruction" box the Wav file disappears leaving the ”Play sound:” with no following Wav file. Can someone please assist. Thanks Rattler Link to comment Share on other sites More sharing options...
RB51 Posted November 17, 2014 Share Posted November 17, 2014 Hi Mark - you should now be on V 1.57. Maybe fire up RM get the update and see if there are any differences. R- Link to comment Share on other sites More sharing options...
96RAF Posted November 17, 2014 Share Posted November 17, 2014 It looks like your attempt to doctor the fonts/clours failed Rattler. All I see if formatting code not pretty text. Similar methodology started a site hacking scare a while back. Link to comment Share on other sites More sharing options...
RB51 Posted November 17, 2014 Share Posted November 17, 2014 Just done this myself in 1.57 - and it worked OK. I didn't try this before so can't comment on any differences. Now, in 1.57, after setting "Play Sound" in the "Instruction" box a little magnifying glass comes up for you ro browse to the sound you want. Let us know how you get on. R- Link to comment Share on other sites More sharing options...
rattlerMark Posted November 18, 2014 Author Share Posted November 18, 2014 Thanks for the advice Roger I'll try that and let you know how it goes. Link to comment Share on other sites More sharing options...
rattlerMark Posted November 20, 2014 Author Share Posted November 20, 2014 Hi Roger Thanks for the good advice Roger - I have updated with V 1.57 and all is going well - thanks again Mark Link to comment Share on other sites More sharing options...
RB51 Posted November 20, 2014 Share Posted November 20, 2014 Your welcome. R- Link to comment Share on other sites More sharing options...
