dougal_robb Posted November 24, 2014 Share Posted November 24, 2014 Hi just wondering how much track can I run with a dcc select controller. I am about to buy my track for my first layout and was wondering how much track the select dcc controller runs. Will it run unlimited if i put the dcc point pin things in? Thanks, robbo Link to comment Share on other sites More sharing options...
Yelrow Posted November 24, 2014 Share Posted November 24, 2014 Hi, Dougal, welcome to the forum. There is unlikely to be a problem with power supply to your new track, irrespective of size of track, using the select controller. I have 5 ovals, and 15 points, and change over from elink to select, when children drive my trains, without any problem. Yes, you will have to put in point clips, but unless you intend running sound locos, which have more functions than your select can identify, you will be absolutely fine. john Link to comment Share on other sites More sharing options...
ModelerXYZ Posted November 24, 2014 Share Posted November 24, 2014 Loads. just not any more trains than 3 at a time unless you have a 4 amptraansformer or a booster pack. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted November 24, 2014 Share Posted November 24, 2014 I wasn't aware that the track ran anywhere! :-) You can run four loco's simultaneously with the power available from a Select, but trying to avoid collisions is another matter! For a 'normal' domestic track, you don't need any more power, although the Elite controller is a better buy, as you have two independant speed controllers in one box, and it allows you access to more functions, if you have any sound loco's. If you plan on a really big fixed layout, (more than 20 feet/7Mtrs long) then you might like to think about installing a BUS power feed to the underside of your track boards. It is only a fancy name for a pair of heavy wires, with lighter links to each piece of track, to reduce power losses caused by all the rail joints. Some people swear by the system, others swear AT it! Link to comment Share on other sites More sharing options...
dougal_robb Posted November 24, 2014 Author Share Posted November 24, 2014 Thanks guys, i've been looking for an answer for ages but couldn't find one till now. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted November 24, 2014 Share Posted November 24, 2014 Just ask the right question in the right place - and you usually (but not always!) get the right answer! :-) Link to comment Share on other sites More sharing options...
