dynax Posted December 14, 2014 Share Posted December 14, 2014 Trying to install the above but not in the list of locos on RM, tried inputting the R number but nothing shows up, can do it manually from loco ID, but no sounds, any help appreciated, also have the DoG TTs no problems with that, don't think it's an update issue as I've just downloaded the software and set it all up on the Elite, thanks,Mike. Link to comment Share on other sites More sharing options...
Yelrow Posted December 14, 2014 Share Posted December 14, 2014 Dynax, hi, not a problem. None of the TTS, locos are in RM, yet. Just type in the name, just as you would a Bachmann loco. Presume you have put on Prog track, and changed from 003. Enter your new number in box, then type in from instructions, all functions(18). test them as you go. If still a problem, let us know. john Link to comment Share on other sites More sharing options...
dynax Posted December 14, 2014 Author Share Posted December 14, 2014 Dynax, hi, not a problem. None of the TTS, locos are in RM, yet. Just type in the name, just as you would a Bachmann loco. Presume you have put on Prog track, and changed from 003. Enter your new number in box, then type in from instructions, all functions(18). test them as you go. If still a problem, let us know. john Thanks John, i've changed all loco id's with the elite directly, i just thought i would try rm before deciding wether or not to buy it, Mike. Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 14, 2014 Share Posted December 14, 2014 Hi dynaxThe TTS Cock O The North is not included in RM list of locos yet.Search R3155 and edit the wording, I put 2-10-0 Cock 'O The North TTSYou will need to change the loco ID on your program track from 003 to a number not used and your sounds as John saysNice train MikePJ Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 14, 2014 Share Posted December 14, 2014 Mike, you might check out the many threads on the RM forum as this has been covered a number of times before. Do a search on TTS or just look down the list of threads for those covering the various TTS locos. Doesn't matter which you look at as the functions are all the same. Check particularly for how to set up latching functions. Graskie in particular has some good advice on these. Link to comment Share on other sites More sharing options...
