dwragg Posted December 17, 2014 Share Posted December 17, 2014 I have just recieved my new Gadwell from Hornby, a replacement for one where the sound refused to work. Now I have sound (thank you Hornby) but can't change the volume, can anyone guide me though what to do. Is it me or are the manual instructions not that clear? I have a Elite controller with 1.3 firmware. Link to comment Share on other sites More sharing options...
george_henderson1 Posted December 17, 2014 Share Posted December 17, 2014 I have the elink set up and I'm wondering if it could be a firmware issue, Mabee there's an update for the elite as I had one last week for the elink.worth trying anyway, I hope this helps sometimes dcc can be a little frustrating.gsvh30 Link to comment Share on other sites More sharing options...
96RAF Posted December 17, 2014 Share Posted December 17, 2014 I advise updating your elite to v1.41 from the hornby website download area.TTS sound volume can be adjusted in two ways. 1. By adjusting the overall volume of all the sounds at once - see your TTS info sheet to find out which CV to change for your loco. 2. You can adjust individual sounds by amending their particular CV. Again see your instructions.if you mess the sounds volumes up then you can write value 5 to CV8 which resets only the sounds to factory levels.rob Link to comment Share on other sites More sharing options...
dwragg Posted December 17, 2014 Author Share Posted December 17, 2014 Thanks for the replys. Rob, I have done as you say (well, I think I have!!...will try again) I will update the Elite before doing anything else. I've talked to Hornby CCare about the website's page 'error' for downloading, they said send the Elite back to Hornby and they will update free of charge, but I won't do that until christmas is over. Link to comment Share on other sites More sharing options...
pidder Posted December 17, 2014 Share Posted December 17, 2014 Returning a controller to Hornby for a free update is a tad expensive. I returned my Select recently, back very promptly but I felt obliged to cover the value while in the mail, cost some £8 odd. Wonder if Hornby could set up an "on-line" upgrade for the Select? (Apologies for butting in on this thread). Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 17, 2014 Share Posted December 17, 2014 Dw, try the upgrade yourself. Get it from the download section and follow the instructions meticulously. If it doesn't work, as a very few have found, then send it to HCC. Link to comment Share on other sites More sharing options...
dwragg Posted December 17, 2014 Author Share Posted December 17, 2014 Fishmanoz, I have tried to do that but it seems to have an 'error on page' so get knowhere with that.Have others found the same problem? Link to comment Share on other sites More sharing options...
96RAF Posted December 17, 2014 Share Posted December 17, 2014 Returning a controller to Hornby for a free update is a tad expensive. I returned my Select recently, back very promptly but I felt obliged to cover the value while in the mail, cost some £8 odd. Wonder if Hornby could set up an "on-line" upgrade for the Select? (Apologies for butting in on this thread). Select doesn't have a pc interface so no way to diy upgrade.i presume HCC take the back off and plug inside somewhere.can anyone post select internal pictures, but don't risk damage to your controller. You may need a triangular screwdriver. Link to comment Share on other sites More sharing options...
pidder Posted December 19, 2014 Share Posted December 19, 2014 RAF96 I have just caught up with your post. The Select does have an Xpressnet socket, what would this be for? Could it be made to operate as a PC interface? Link to comment Share on other sites More sharing options...
96RAF Posted December 19, 2014 Share Posted December 19, 2014 RAF96 I have just caught up with your post. The Select does have an Xpressnet socket, what would this be for? Could it be made to operate as a PC interface?Afaik it's only for connecting to an elite when used as a walkabout. Link to comment Share on other sites More sharing options...
pidder Posted December 19, 2014 Share Posted December 19, 2014 RAF96 Thanks for your reply. Google describes Xpressnet as a computer interface and my suggestion was that someone knowledgeable at Hornby could set something up, via this socket, to enable the Select to be upgraded online, similarly to the Elite. Is this beyond the capabilities of some computer wizard? I shall have to ask my own PC advisor.. he's coming home Monday for the holiday... Link to comment Share on other sites More sharing options...
Graskie Posted December 19, 2014 Share Posted December 19, 2014 I ran my DoG for my father-in-law a couple of days ago. He has two hearing aids and thought the sounds were a bit loud. I have slight to moderate hearing loss, and even without hearing aids yet, I agreed with him. I had already set the overall volume right down to the minimum. What more can I do? Link to comment Share on other sites More sharing options...
96RAF Posted December 20, 2014 Share Posted December 20, 2014 The tender has a couple of moon shaped holes over the wheels which you could partially block.I found DoG needed turning down to value one for my 12x12 ft room. Tornado is ok on one. Link to comment Share on other sites More sharing options...
