RDS Posted December 24, 2014 Share Posted December 24, 2014 I have just been offered an upgrade to v1.59 after opening RM. Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted December 24, 2014 Share Posted December 24, 2014 You should let RailMaster download and install it. The update is a maintenance release, fixing some minor bugs and adding a few minor features. If anybody has trouble with the automatic download (due most lilely to antivirus/firewall software blocking it) then you can download and install manually from www.powerpos.com/rail-master.rm_setup.exe. Link to comment Share on other sites More sharing options...
RDS Posted December 24, 2014 Author Share Posted December 24, 2014 Thanks HRMS. I have installed it. Incidentally, I have always had to use the powerpos method but I am quite happy to do it that way. Link to comment Share on other sites More sharing options...
Teedoubleudee Posted December 24, 2014 Share Posted December 24, 2014 You should let RailMaster download and install it. The update is a maintenance release, fixing some minor bugs and adding a few minor features. If anybody has trouble with the automatic download (due most lilely to antivirus/firewall software blocking it) then you can download and install manually from www.powerpos.com/rail-master.rm_setup.exe.Hi HRMS, Does the manual get updated with every release? I'm currently on 1.58 but the manual I have is 1.57 (October 2014) Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 24, 2014 Share Posted December 24, 2014 It is Christmas Eve! Hornby have emailed me also, they found bugs in RM for the Train-Tech 3 and 4 aspect signal coding and have fixed them. These and other bug fixes are in the 1.59 version download. Incredible service from HRMS, we are very grateful and wish you all a Very Happy Christmas PJ Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted December 24, 2014 Share Posted December 24, 2014 Teedoubleudee - The version numbers of the manuals are not generally updated where a RailMaster maintenance update has been released, only when new features requiring documenation are introduced. Link to comment Share on other sites More sharing options...
St1ngr4y Posted December 24, 2014 Share Posted December 24, 2014 It is Christmas Eve! Hornby have emailed me also, they found bugs in RM for the Train-Tech 3 and 4 aspect signal coding and have fixed them. These and other bug fixes are in the 1.59 version download. Incredible service from HRMS, we are very grateful and wish you all a Very Happy Christmas PJ Hi PJ,Have you had a chance to try out your TrainTech bug fixes yet?I have tested mine, and I still have exactly the same faults.It's even worse - if, from a program, I send repeated "Stop" commands, a 2-aspect signal will "toggle" between red and green!!!Bah Humbug :-(Ray Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 24, 2014 Share Posted December 24, 2014 It is Christmas Eve! Hornby have emailed me also, they found bugs in RM for the Train-Tech 3 and 4 aspect signal coding and have fixed them. These and other bug fixes are in the 1.59 version download. Incredible service from HRMS, we are very grateful and wish you all a Very Happy Christmas PJ Hi PJ,Have you had a chance to try out your TrainTech bug fixes yet?I have tested mine, and I still have exactly the same faults.It's even worse - if, from a program, I send repeated "Stop" commands, a 2-aspect signal will "toggle" between red and green!!!Bah Humbug :-(Ray Hi RayNot yet, I won't get chance for probably five days.PJ Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 24, 2014 Share Posted December 24, 2014 You should let RailMaster download and install it. The update is a maintenance release, fixing some minor bugs and adding a few minor features. If anybody has trouble with the automatic download (due most lilely to antivirus/firewall software blocking it) then you can download and install manually from www.powerpos.com/rail-master.rm_setup.exe.Hi HRMS, Does the manual get updated with every release? I'm currently on 1.58 but the manual I have is 1.57 (October 2014) Hi Teedoubleudee As HRMS says it it not always updated but, I recall saying a few days ago mine RM Guide is November. Do a download manyally and see if it is a newer version. I am not able to check mine at present. PJ Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 24, 2014 Share Posted December 24, 2014 You should let RailMaster download and install it. The update is a maintenance release, fixing some minor bugs and adding a few minor features. If anybody has trouble with the automatic download (due most lilely to antivirus/firewall software blocking it) then you can download and install manually from www.powerpos.com/rail-master.rm_setup.exe.Hi HRMS, Does the manual get updated with every release? I'm currently on 1.58 but the manual I have is 1.57 (October 2014) Link to comment Share on other sites More sharing options...
