alpachi Posted January 10, 2015 Share Posted January 10, 2015 Hi guy's, I got the Western Master digetal elink for christmas and I am having problems with the track. The DCC is read by the computer and the drive all good but when I connect the track a window pops up saying [DCC controller error ] Please clear the short circuit, only when I take off the siding track the train runs ok. Please help, Link to comment Share on other sites More sharing options...
Yelrow Posted January 10, 2015 Share Posted January 10, 2015 Alpachi, hi welcome to the forum. Have you fitted the little clips to your points, to make them DCC. john Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 10, 2015 Share Posted January 10, 2015 Check your siding track including the point carefully as it would seem you have a short circuit in there somewhere. Link to comment Share on other sites More sharing options...
Woody52 Posted January 11, 2015 Share Posted January 11, 2015 Hi alpachi, check you power conector track, some of the Western Masters were shiped with the incorrect DC Power Track (R8206). The correct one is the R8241 Digital Power Track. Check underneath the track.If you have the R8206, simply pop off the plastic bridge covering the contacts(top side of track) and remove the resistor conecting the two track contacts, and clip the bit of plastic back in place. If you don't want to attempt this yourself just have it replaced with the correct one(R8241).Hope this fixes your problem.Peter. Link to comment Share on other sites More sharing options...
96RAF Posted January 11, 2015 Share Posted January 11, 2015 He means capacitor not resistor. Same thing though - if its there snip it out. Link to comment Share on other sites More sharing options...
Robespierre Posted January 18, 2015 Share Posted January 18, 2015 Very interesting. My son's Somerset belle was a pig to get working and then he trod on the power track and broke it.So I bought a replacement, which worked well, even though it had the wrong product code.... Although clearly the right replacement on the basis of this thread. Link to comment Share on other sites More sharing options...
