Trainboy709 Posted January 30, 2015 Share Posted January 30, 2015 Hi,I bought a hornby digital set a few years ago which came with a Select controller. Ever since i have had the same problem. I have made the loco reverse into a siding to couple up to the wagons it came with, and couldn't go back into forwards mode. The only way i could fix this was to unplug and plug it in again. But i need a solution since my collection is steadily growing and it is a nuisance having to unplug and replug the remote. I'm not sure if this is the way it is designed or if it is just my controller. I think number two. Any help would be greatly appreciated, Trainboy709 Link to comment Share on other sites More sharing options...
Trainboy709 Posted January 30, 2015 Author Share Posted January 30, 2015 I just had a look at the manual and it turns out that the entire left directional button is dysfunctional, even though the LED is lit! I couldn't complete any of the commands that require the use of that button. I would very much appreciate any suggestions. I think i should get it serviced. Or looked at. Link to comment Share on other sites More sharing options...
Yelrow Posted January 30, 2015 Share Posted January 30, 2015 Trainboy, hi. If your select is several years old, its firmware, will not be up to date. There were problems with the older ones, which were then updated, and are now fine. This is a free service provided by hornby. Contact them, at margate/ ashford, and then return it for free updating. john Link to comment Share on other sites More sharing options...
Michael_A Posted January 30, 2015 Share Posted January 30, 2015 While it is worth checking the firmware it's not an easy process to upgrade it for the less experienced, and it's far more likely this is a faulty button if it's the only one not working.I would call Hornby before doing anything. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 30, 2015 Share Posted January 30, 2015 Are you getting confused with Elite Michael. Select firmware can only be done by Hornby. Contact HCC about returning it for repair and/or firmware upgrade. Link to comment Share on other sites More sharing options...
Trainboy709 Posted January 31, 2015 Author Share Posted January 31, 2015 Trainboy, hi. If your select is several years old, its firmware, will not be up to date. There were problems with the older ones, which were then updated, and are now fine. This is a free service provided by hornby. Contact them, at margate/ ashford, and then return it for free updating. johnThanks! I will try contacting hornby then. But if i take it to a local model shop couldn't they be able to fix the faulty button? It is probably the firmware.Thanks Link to comment Share on other sites More sharing options...
Yelrow Posted January 31, 2015 Share Posted January 31, 2015 No, your firmware will be out of date. It mat not be a faulty button. john Link to comment Share on other sites More sharing options...
96RAF Posted January 31, 2015 Share Posted January 31, 2015 According to a separate post where the poster was having problems following the manual when comparision was made with the the latest manual download the procedure was different.The manual and the firmware must obviously match.Also the firmware upgrade can only be done by Hornby not by your local shop or handy mate. Link to comment Share on other sites More sharing options...
