gasway Posted January 30, 2015 Share Posted January 30, 2015 The red directional lights on my loco only work in one direction Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 30, 2015 Share Posted January 30, 2015 Hi gasway, welcome to the forums. So are you telling us that it has directional lights, the White forward light works whichever way the loco is going, but the red rear light only in one direction? And has that red one ever worked, or is it non-functional from new? If the loco is new, take it back. If you want to check it yourself, you will need to remove the body as per the instructions with it, then I would look for a wiring problem first. The LED light may be broken but these are very reliable so unlikely. Link to comment Share on other sites More sharing options...
96RAF Posted January 31, 2015 Share Posted January 31, 2015 If its not going back and you intend dismantling it then download the associated Hornby Service Sheet for the R-number of your particular loco. This is likely to be HSS276 as the other service sheet HSS376 is for the Railroad Class 31 which doesnt have lights.Looking at the service sheet the lighting arrangement is fairly complex but it could be as simple as a wire off at the light box at one end or where the wires connect to the ends of the main circuit board. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted January 31, 2015 Share Posted January 31, 2015 Is there a switch undeneath the loco that turns off the red lights at one end, for when it is towing a rake of rolling-stock? That might have got itself switched off! It will only be a tiny thing, so look carefully! Link to comment Share on other sites More sharing options...
96RAF Posted January 31, 2015 Share Posted January 31, 2015 Nothing obvious on the service sheet 2..eric Link to comment Share on other sites More sharing options...
