Chellbel Posted June 6, 2015 Share Posted June 6, 2015 I have just received a second hand turbo blast set and the cars just sit and do nothing yet if I lift the back a touch they then work if I use other cars from a different set it all works fine. Can I assume the turbo cars are goosed Link to comment Share on other sites More sharing options...
Andy P. Posted June 7, 2015 Share Posted June 7, 2015 You have bad braids or a faulty connection between the braids and the engine.Replace the braids and see if that helps. Link to comment Share on other sites More sharing options...
