Amateur modeller Posted October 18, 2015 Share Posted October 18, 2015 i am a born again modeller and have bought some starter kits to develop my skills after a 45 year absence. I am working on the Mini Cooper S kit and rather than using the Union Jack strip for the roof, I have decided to paint the roof white. I have applied 2 coats of primer (no 1) and have now applied so far 2 coats of White ( Humbol acrylic white no 130) but the colour is more greyish white and as the 130 paint is very watery, how many coats do I have to apply for the roof to look like white gloss or am I doing something wrong? Link to comment Share on other sites More sharing options...
Braille Dave Posted October 18, 2015 Share Posted October 18, 2015 Silly question, how long did you wait for the primer to dry before you put on the subsequent coat? Personally I would use matt white as a primer, if your top colour is going to be anything like white, cream or even yellow. Link to comment Share on other sites More sharing options...
Amateur modeller Posted October 18, 2015 Author Share Posted October 18, 2015 from memory, about 2 hours between each coat and then 24 hours before applying the first coat of 130. i remember when I bought the grey primer, the guy said iyou could use it for any colour Link to comment Share on other sites More sharing options...
Braille Dave Posted October 19, 2015 Share Posted October 19, 2015 You can use grey for any colour, the problem is, as BLJ says, that white is notoriously bad for coverage...For any paint. If you have a look at custom car paints, you'll see they have four primer colours, white, grey, dark grey and black. As a rule of thumb, I would use matt black for very dark colours, grey for mid colours and matt white for pale, or difficult colours, like yellow (a real s*d, of a colour!) Link to comment Share on other sites More sharing options...
ironsides Posted October 19, 2015 Share Posted October 19, 2015 I would use white primer for some paler colors, white red and yellow and probably silver(although a light grey would also work but the top coat would be a shade darker), grey under camo colours such as green and brown and black under very dark colours etc.... black is not a favourite under coat for me though... I dont use a spray gun but for large areas would use a flat brush and thinned paint in several coats, I use Acryllics usually.-) Link to comment Share on other sites More sharing options...
vimal_indrasoma Posted October 19, 2015 Share Posted October 19, 2015 Gloss black is recommended for some metallics and metalizer paints - fluorescents (hi-viz orange/red) usually needs matt white. Link to comment Share on other sites More sharing options...
Amateur modeller Posted October 19, 2015 Author Share Posted October 19, 2015 Thank you all so much for your valued input to my question...I will now get some Matt White Primer. Link to comment Share on other sites More sharing options...
Ratch Posted October 19, 2015 Share Posted October 19, 2015 Halford's Appliance White aerosol gives a good finish (even on grey primer). Link to comment Share on other sites More sharing options...
Bert1707820915 Posted November 24, 2015 Share Posted November 24, 2015 Halford's Appliance White aerosol gives a good finish (even on grey primer).Yep - I'd go along with this, it's a great spray for large areas of white topcoat (eg. Ant-flash white Vulcan or TSR2). I use this over grey primer - the coverage of the white is good and using the grey primer allows you to easily see which areas have been sprayed (using white over white primer makes it a bit more awkward!). Link to comment Share on other sites More sharing options...
Jonathan Mock Posted November 25, 2015 Share Posted November 25, 2015 I've been expermenting with airbrushing white paint over - wait for it - black primer. Sounds anomalous? Actually there is sound colour science behind it! Link to comment Share on other sites More sharing options...
Braille Dave Posted November 27, 2015 Share Posted November 27, 2015 Yes I can see that... you get an even base, which, as long as you put the white on in an even coat should stop the patchy look, Link to comment Share on other sites More sharing options...
Jonathan Mock Posted November 28, 2015 Share Posted November 28, 2015 Yes I can see that... you get an even base, which, as long as you put the white on in an even coat should stop the patchy look, It's all about contrasts, Dave. I use less white paint spraying over black than over grey or even white. And the covering power of modern acrylics when airbrushed means the old adage of painting from light to dark is pretty much redundant these days. Link to comment Share on other sites More sharing options...
