Classic Track Power Supply
Hi there,
My dad recently dumped all my old Scalextric on my door during a lockdown clear out. So I did what any self respecting 34old does. Set it all up to have a play.
Ran into a few issues. Track was first off horrible, 15-20years in a cellar hadn't done it any favours. Cleaned it all up. Oiled the track with some WD40 in lieu of anything better and re soldered a couple of connections on cross over sections.
Everything generally works ok. However I've noticed an issue with the power supplies. I've got two. An old blue round open terminal style, which is spitting out voltage but isn't getting to the track, guessing broken controllers. Second is an old, at a guess 90's, power base. This overall works ok but there is a noticeable power drop off at the furthest points. Also the triggers on the controllers at full pull cut power completely.
What would you all suggest as a fix? New supply? Old test power base?
Thanks
Resurrecting old track and cars can be fun but it is very time consuming and often doesn't last long.
You can try power taps, simply connect wires from the track where the pwoer base is connected to the fartherst points.
Double check all the connections.
The power juice of choice is INOX M3 that is readily available in the UK and Australia/NZ. it works much better than WD40.
