Loz2103 Posted January 17, 2021 Share Posted January 17, 2021 Hi all,Total newbie here, so apologies in advance for forum faux Pas and just complete ignorance.I have a digital chipped McLaren which has just started running slowly. I was wondering if there was a walk through guide on the steps I should take on how to debug issues? Obviously, check braids, then I was wondering what voltage should be measured at the motor, for example. What else should be checked? Similarly, is there a guide anywhere on the best way to take a car apart? If I need to replace the motor, for example?If I run the car at full throttle with the wheels up, the speed seems inconsistent. If I run it like this for a while it seems to speed up and stay fast. If I then run it round the track, it seems to slow down again over a couple of laps. Some of this might be subjective and not actually be happening but it does seem to be the case. Thanks in advance,Loz Link to comment Share on other sites More sharing options...
Andy P. Posted January 20, 2021 Share Posted January 20, 2021 Digital specific stuff (assuming you are using ARC PRO) are best covered here: https://slotracer.online/arc-pro-guide/When trouble shooting digital cars it is always best to remove the digital chip and test the rest as the chip could be the problem. Link to comment Share on other sites More sharing options...
